Charcoal or GAS grill?
Hoober
4,413
58
Originally posted by: Ameesh
propane, its soo much easier to maintain and the tatses the same.
You've never had a master griller cook you a steak on charcoal... there is no comparison.
Jan 18, 2001
14,465
Unless you want to spend the bucks and get a really good gas grill, go with charcoal. What you need in a grill is HEAT. Gas grills do not get hot enough, unless you have a high end model.
I have cooked on charcoal for 15 years. I am quite good at it. I have also cooked on Gas (going on 5 years), on both cheap and very nice grills.
At the moment I prefer gas because:
1) Easier to start --> requires less lead time
2) Easier to clean
3) Cools down Faster
4) better control over low temp grilling for certain foods such as mushrooms, peppers, bread, veggies.
Very High heat is require to carmalize meat. IMO, this why people think charcoal tastes better. I.E., because most people compare charcoal to cheap gas grills...it aint the source of heat, its the amount of heat that is important.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: spidey07
LOL!
Gas still is the best for a steak. You have to cook it VERY hot and VERY fast.
No, no you don't. If you do that then you end up with that burnt crap that people call "searing" but is really just burnt steak. I send steak back if it comes out burnt like that in a steakhouse.
ZV
Hoober
4,413
58
LOL!
ZV
Exactly. Slow cooked and juicy. That's how to cook a steak.
spidey07
65,469
If you cook it right then the thing explodes with juice. A nice medium rare filet or strip can be cooked about two minutes a side, there is no burning just a slight carmelization on the outside for flavor and seal in the juices.
oh well...different strokes I guess. Slow cooked = taste like charcol and not like meat. Fast cook - taste like wonderful steak.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
LOL!
ZV
Barely cooked and juicy is even better. :D Somewhere just past rare but not quite to medium-rare is perfect. (Dangit, now I'm hungry.)
ZV
Hoober
4,413
58
Every time I've had a flash-burned steak off of a gas grill cooked under five minutes a side it's been tough to cut through and even harder to chew. There isn't a steak flavor to be found in any bite.
Now, I've never had a steak cooked the way you describe so that might be good. It does sound good. I still think charcoal fires are better than gas. Might have to start up the grill tonight.
spidey07
65,469
LOL!
ZV
ZV
That's not juicy! The fat is still mostly solids. Raw meat != juicy.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: n0cmonkey
Wood. Nothing beats the taste.
This is why one adds hickory chips (preferably ones soaked in water) to the charcoal. :)
ZV
grillmasterP
468
I use the grill frequently so gas is much more convenient as far as cleaning and temp control- Especially if you cook for a large family or for parties. Cleaning / disposal of charcoal can be a pain if you grill 1-3 times a week.
Also, you can always soak some mesquite chips and add those (wrapped in foil or smoker box) to the gas grill for a hint of smokey flavor. Ive never used the liquid smoke stuff.
If you don't plan on using the grill frequently - just a few times over the summer - charcoal will be fine - just dont go crazy with the lighter fluid so that the food taste like its been marinated with gasoline.
Also - When it comes to ribs, brisket, whole chickens & duck - I prefer to smoke /barbecue with our wood burning grill/ fire box smoker -
indirect heat, cooked over a longer period of time - Well worth the hard work ! nothing like cooking with pecan.
n0cmonkey
42,936
ZV
That's cheating ;)
Most of the time I use gas. But if I have the time, and the inclination, nothing in my opinion can beat a nice wood fire. But it takes a long time, so I don't do it often.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: ZenmervoltBarely cooked and juicy is even better. :D Somewhere just past rare but not quite to medium-rare is perfect. (Dangit, now I'm hungry.)
ZV
Blood = juicy. :p ;)
I don't really like it raw but I definitely like it to still be red inside. Pink is good, but not as good. :)
ZV
spidey07
65,469
yeah Z,
Nice medium rare....mostly pink with a good red center.
In fact I'm grilling tonight as I do almost everynight when the temperature is decent (i'm not hard core enough to grill in the winter).
On the Gas or Charcoal grill - They both have their uses just make sure you don't skimp and buy a cheap grill.
rudder
19,441
86
Originally posted by: bentwookie
summertime coming, need to get a new BBQ grill.
debating about taste and conveinence...comments?
charcoal for taste
gas if you are concerned about the environment
JACKHAMMER
I am in the same spot. I am going to buy gas, when cooking for a lot of people an EVEN cooking surface is really important - and that is hard to get right with charcoal.
Hayabusa Rider
Admin Emeritus & Elite Member
Jan 26, 2000
50,879
4,268
charcoal
Bought a Char Griller with a smoke box last year. Best thing evar
I recommend charcoal of course, and get a chimney type starter. You fill it, and there is a space for newspaper at the base that you light. In short order you have hot coals minus funky lighter fluid taste. With the smoke box, you can do real BBQ, if you have a hankering for it.
