ManBearPig
I have a 2007 camry, i hear that i have to change the air filter every 10k miles. Is this true?
Originally posted by: BassBomb
10k? Mine has lasted about 70 so far without a change, still clean
(2002 Civic)
(2002 Civic)
Originally posted by: Throckmorton
DO NOT DO THIS. K&N filters let in substantially more dirt.
http://home.stny.rr.com/jbplock/ISO5011/SPICER.htm
People who don't know any better use them. And they'll always defend them by saying racecars use K&N, etc etc... How long is a race car engine meant to last? Common sense... How do you think they flow more air? And the ONLY time the extra 2 horsepower matters is at wide open throttle. In every other situation you are using as much throttle as you need to go the speed you want. If you got 2 more from an air filter, you'd just throttle down slightly to compensate, adding restriction at the throttle plate to compensate for the better flow at the filter. This is why the mpg increase claims are BS. The way you control the engine's horsepower IS by restricting airflow, which the ECU adjusts fuel flow for.
This is simply untrue. Lots of people like to claim that the K&N is not good a filter. Then of course there's the 'evidence' of some flow numbers and particle counts. I don't want to imagine how much time that guy wasted doing the tests and then putting together the plots. I've had a K&N on my truck since the day I bought it 8 years ago. I don't know how long the previous owner had it on but I've got almost 80,000 miles with it.
My counter: Blackstone Oil Analysis
EDIT: Forgot to add the link
K&N filter efficiency of 96.8% vs the highest AC Delco at 99.93%...Originally posted by: Throckmorton
Yes, now I see that the extra 3.13% makes all the difference. :laugh:
It's a good thing I've been driving on the streets rather than in Arlen Spicer's test lab back in 2004. 😛
What do you mean "this is simply untrue"?? What's untrue? It's a fact that K&N lets more dirt through per volume of air. How exactly do YOU think they make it less restrictive? I don't see how he wasted time though-- he proved that K&N doesn't filter as well as a paper filter. And you know what? An air filter's job is to filter air. Like he says, too much dirt is any more than necessary.
Your engine may have been running for a long time, but that doesn't mean it likes sucking in more dirt. Your oil may be relatively clean because your oil filter does its job, or because you live in a clean environment. You'd have to compare the numbers to averages for your locality, otherwise it's not scientific at all.
Of course you'll be defensive because you don't want to believe that you're putting more dirt into your engine than you would with a regular filter, or you might tell yourself it's not doing any harm, but you really need to ask yourself what benefit you see from K&N. How often do you use wide open throttle, and do you notice the 2hp?
80k miles on your truck doesn't quantify anything either. "Any more than necessary is too much" means erring on the side of caution. Obviously we love our vehicles-- why put 45x as much dirt into them than we have to for an unnoticeable horsepower boost? Some people swear by regular oil and fram oil filters and run for many many miles, but a lot of us use synthetic to get some extra life out of our engines and make them run better for longer. Why would we make an exception for air filters, and say "oh well, 3.2% dirt isn't so bad"? I put the best synthetic oil in my Jeep, the best oil filter, I put the best synthetic wax on the paint, the best tires for my application, etc... and likewise I put the best air filter that I know of.
Keep in mind the difference between an engine that runs well and an engine that runs but doesn't have good compression and is less efficient is only a few microns of tolerance.
