Pepsi90919
- Oct 9, 1999
- 25,162
- 1
- 81
Originally posted by: tfcmasta97
So here we will finally learn:
How many ATOTers does it take to change a lightbulb?
24 replies and it's still not changed
Originally posted by: KillerCharlie
It's incredible how shoddy the wiring is though...
Originally posted by: oldsmoboat
It probably pulls straight down on is on long clips.
Originally posted by: feralkid
How did you come to that conclusion?...I mean you're the guy who can't figure out how to change a light bulb.
The metal trim ring is simply clipped up there .Pull it straight down and then you will be able to grasp the bulb.
Next time, put the correct style bulb in it.
We need a punchline.Originally posted by: tfcmasta97
Originally posted by: danzigrules
there are lots of fixtures out there that ya grab the glass and just pull down. There are metal spring clips holding the glass in the base
Repost
Repost
well if your post would have made more sense then maybe I wouldn't repost.
Q: How many porn actresses does it take to change a light bulb?
A: Well, it looks like 2 of them are really doing it, but the real answer is actually none. They're just faking it.
Q: How many smokers does it take to change a light bulb ?
A: At least five. If they all light up together the light bulb will do so too.
Q: How many gay rights activists does it take to change a light bulb ?
A: None: The bulb shouldn't have to change for society to accept it.
Q: How many men does it take to screw in a light bulb ?
A: One -- men will screw anything.
