jjzelinski
- Aug 23, 2004
- 3,750
- 0
- 0
Originally posted by: Starbuck1975
Went searching for the Samsung 226BW, and couldn't find any local retailers selling it.
I did stumble upon the Gateway FPD2275W...my first impression was that it looked much better than any other 22" I have seen...will have to read up more on this LCD.
That was my impression as well...I saw the Gateway 22" at Best Buy, setup right next to the gateway 24". I honestly could not tell a difference, with the expeption being that the 24" did have better viewing angles...but I cannot think of many scenarios where I need to view my screen from an angle.uses the same panel all other 22"'s have, I ended up buying the Gateway 24" but was looking at the 22" seriously. Best Buy has the 22" on demo, image looked killer. I know people here tend to really hate on all 22"'s but I don't see how anyone could say it's a bad screen.
Originally posted by: CloE
isn't it painful to watch DVD on these huge LCD with 1900x1200? I can't stand the image quality of regular dvd movies on my dell 2007wfp, because the movies are designed for TV, not high res screens.
Originally posted by: Matt2
Anyone who thinks a TN panel even comes close to S-PVA/S-IPS quality either doesn't care or doesn't know what they are looking for.
Maybe it's cause I went from a TN panel to an S-IPS, but the difference to me is like night and day. Even going from S-IPS to S-PVA was difficult on my eyes for a week or so.
You couldn't pay me money to go back to TN.
I found another Best Buy that had the LG 226WT actually hooked up to a dedicated PC...it made a much better impression than seeing the same monitor on the LCD wall of screen saver goodness.
One concern I have with 22" LCDs, or any widescreen for that matter, is scaling.
Does anyone know if the LG 226WT and Samsung 226BW have 1:1 pixel mapping? I have seen the "stretching" effect of some games that don't scale well to widescreen...I know there are forums out there that offer scaling fixes for most games, but I also want the option to run a game at 4:3 on a widescreen should there not be a suitable work around to prevent scaling issues.
Which brings us full circle back to the GPU issue...I know my 7900GT KO is capable of running at 1600x1200, but doesn't mean I am going to get framerates worth a damn.Brings up another benefit though of the 24" panels. You can run 1600x1200 and only lose 160 vertical bars of resolution on both sides. With a 22", the closest you'd get is 1280x1024 with some vertical and horizontal on all sides.
Ugh...I still can't find an LCD that I like.
I guess the point I am at now is that I want an LCD suitable for gaming, with the color depth and vibrancy of the NEC 20WMGX2, but larger than 20.1"...which probably means S-IPS panel...although I know that the latest trends are all going towards the lower cost TN panels. Price point I am willing to spend at is $500. Don't need USB hubs. Don't care about stand adjustability. Simply want a high quality panel that has a response time suitable for gaming and 1:1 pixel mapping.
Are there any LCDs on the horizon that are worth waiting for? I am not desperate to pull the trigger, and can wait for a model to come out that appeals to me.
Originally posted by: kmmatney
Give up on the 1:1 pixel mapping requirement. Almost no LCDs do that, and your video card should be able to handle that. I've had no trouble with 1:1 pixel mapping with my last few NVidia cards (ATI cards have trouble last I tried, though). In any case, you are just limiting yourself with this requirement. The Dell LCDs (FP2007, FP2407) are the only ones that I know of that have built in 1:1 pixel mapping.
Here is where I get confused, and hence my hang-up on 1:1 pixel mapping.You can always run games at a lower rez on the 24", & you'll have a lot more viewing area than the 22s.
