Originally posted by: EF9
Damn, this doesnt support the bass/treble advance controls like my onboard sound but at least my onboard sound had an eq you can adjust. The Chaintech does sound a bit clearer but nothing to rave about. This is in reference to the Logitech Z-560 speakers with different types of music compared between my realtek 5.1 on board sound and the Chaintech 7.1. Oh. forgot to mention I will be trying the Prodigy hack.
Originally posted by: BenJeremy
Please remember, people... DACs do NOT matter if you are using the digital output.
This is the real advantage of the card. Optical output means you are getting a direct digital signal out to your Dolby Digital decoding reciever in 7.1 sound (backward compatible to 5.1 AC-3). Piss on the DAC in this configuration, since the DAC is not touched.
I'm amazed there aren't MORE Dolby Digital cards out there... especially from Creative. There are currently three contenders for Digital output - nForce 2 Soundstorm, Intel HD Audio, and VIA ENVY HT. Any other cards that say they support digital out is basically LYING - because what they actually support is 3x2 channel PCM (Creative) for gaming or no digital output for gaming at all. Unless your stereo has 3 digital decoders (like Creative Labs' special speaker sets), you will never get anything but 2 channel digital sound for gaming.
Older cards do support "pass-thru" for AC-3 off of a DVD movie played through certain DVD players, but this is merely a digital shuffle.
Games on "older" cards certainly can have 5.1 or even 7.1 channel sound, but it's output via ANALOG channels (or the aforementioned multiple PCM channels), meaning a rat's nest of cables to your reciever or amplified speaker set, and the signal loss/noise associated with that setup.
In short, this card is GREAT for those with a Dolby Digital DECODING receiver with an Optical SPDIF in. It will consume a few clock cycles during games, but if you are playing on a weak CPU, why bother with 5.1 audio, anyway?
Hopefully, Intel and VIA's chipsets will put the heat on Creative Labs (nVidia has taken a massive step back by removing DD support from Soundstorm products) to finally add USEFUL features to their sound cards... but on the other hand, they make a lot of money selling their special speaker setups to people who don't know better.
I think that you are slightly confused. (Or I am - one of us at least.)
There is a difference between simple playback of pre-recorded/encoded Dolby Digital content, vs. real-time live encoding. The latter was the reason for the fanboyism about the SoundStorm. Supposedly, Intel's new audio solution will also do real-time DD encoding, probably in software on the host CPU. I wasn't aware that the Via Envy24 was capable of this real-time encoding feature. Are you saying that it is capable?
Also, you seem to be confusing digital output, with "Dolby Digital"-encoded digital output.
Yes, Creative's solution uses three seperate parallel PCM-encoded digital output channels. I don't own a 7.1 outboard reciever, but surely there is some standard for the 7.1 digital data, besides DD (interleaved PCM maybe?). Otherwise, how would the reciever be able to handle other digital formats, like DTS EX or whatever their 8-channel rather than 6-channel format is?
I had a Vortex2 card back in the day, and it worked great, but it was limited to playback of realtime PCM-encoded digital output, or pre-recorded AC3 or DTS-encoded passthrough digital output.
I'm not even totally sure that realtime DD-encoding is such a great idea, in some cases, because of the compression used. Plus, isn't DD a 5.1 standard? How is that being extended to 7.1 here, if what you say is true, that the Envy24 can do realtime DD multi-channel encoding?
I'm not saying your wrong, only that this is news to me, and I want to learn the truth about all of this.
Originally posted by: dderidex
The only thing the Envy24 can do is the same thing the Audigy can, and the Hercules GameTheater could, and blahblahblah...it has an optical out because it can 'pass through' pre-encoded content. Like, say, from a DVD. It can't actually encode anything itself.
Originally posted by: VanillaH
FYI, the card can be flashed with prodigy 7.1 bios for bit perfect digital out. a fine card that could be couple with a quality DAC like benchmark DAC-1 to bring any analog sound card to its knees.
maybe that explains the loss of analog capability with flashing. makes sense.
the DAC we are talkikng about here is a standalone dac like benchmark DAC or the famous aos piccolo. speakers are analog devices and therefore require a DAC of certain kind to reproduce real world sinusodial signals. the problem is most of these quasi-quality multimedia speakers with digitial input have a crappy DAC built in, easily bested by good soundcards from EMU and RME. so people who flash the av-710 are those who are fortunate enough to be able to afford more expensive DACs.First off, you'd never use a DAC if you were using the digital-out. The signal is digital within the card to begin with, the DAC (or Digital to Analog Converter) is only used for analog output (regular speakers).
The only realy 'gimmick' the Envy24 has going for it is that - again, just using the Wolfson chip - it can output 2-channel audio with exactly the same quality as the Audigy2 ZS can, for a small fraction of the price.
Ok, thanks. That is basically what I originally thought.Originally posted by: dderidex
In any case, this isn't an ability unique to the Envy24 - again, this is the same thing an Audigy, GameTheaterXP, Fortissimo, etc can do. The only realy 'gimmick' the Envy24 has going for it is that - again, just using the Wolfson chip - it can output 2-channel audio with exactly the same quality as the Audigy2 ZS can, for a small fraction of the price.
the DAC we are talkikng about here is a standalone dac like benchmark DAC or the famous aos piccolo. ... the problem is most of these quasi-quality multimedia speakers with digitial input have a crappy DAC built in, ... so people who flash the av-710 are those who are fortunate enough to be able to afford more expensive DACs.First off, you'd never use a DAC if you were using the digital-out.
Many sound cards do unnecessary resampling on digital PCM streams, which can hurt sound quality. With the appropriate drivers, this one does not.Originally posted by: VirtualLarry
So, if this card can't digitally-encode multi-channel "live" content, but only "live" stereo PCM or pass-through pre-encoded digital multi-channel content, how is this card any different at all from any other card that has a digital-out port, if you're not planning on using the card's DACs/analog outputs? I just can't see getting this card for use with digital outputs at all, other than it is on the cheaper scale of sound cards in general.
exactly. plus it should be noted this is for 2channel we are talking about, as most high quality audio we have nowadays only comes in 2channels
Originally posted by: supafly
Could anyone, in a simple way, explain why this card wouldn't be good for gaming?
Originally posted by: Wedge1
This is from AVS Forums thread: http://www.avsforum.com/avs-vb/showthread.php?threadid=364771>>Envy24HT-S - The Definitive Source<< credit to darklordjames
What 3D sound APIs do these cards support?
Through the Sensaura driver included with Envy24 cards, they support A3D, EAX 1.0 and 2.0, and all the other random audio APIs that everything supports. On a side note, Sensaura was recently purchased by Creative Labs. As such, it is possible that Sensaura availability will dissappear from the world, but more likely Creative will continue to liscense it out. That way they make money on every soundcard even if they aren't the ones that are selling them. It is also possible that Sensaura will gain EAX 3.0 and 4.0 support later since it is the daughter company of Creative (the EAX guys).
Why should I get an VIA Envy24HT/HT-S instead of a Creative Labs Audigy 2?
There are several points to cover, but the main ones are as follows.
How important is gaming to you? The Audigy line of cards are generally considered to be better gamer's cards. They support the newer EAX versions 3.0 and 4.0, something that can't be found anywhere else at the momment. They are also essentially the reference card that developers use when making a game, so how the game sounds on an Audigy is pretty certain to be how it was intended to be heard. That isn't to say that the Envy24 cards aren't good at gaming. I personally enjoy the gaming experience on my Envy24HT-S more than I did on the Soundblaster Live it replaced. Through the Sensaura driver that they ship with, the Envy24 cards support all the regular gaming audio APIs, as well as Creative's EAX 1.0 and 2.0. Any half-way decent developer is going to make sure that their game works well on a Sensaura enabled card (pretty much everything that isn't Creative) since Sensaura based cards are a huge percentage of the market. The Audigy is a bit ahead of the Envy24 on gaming, but not by much. Point to the Audigy.
Is Bit-Perfect playback important to you? This is an area where the Envy24 based solutions destroy the Audigy line. Audigy cards are going to resample your CD Audio (and any 44.1khz source) to 48khz in hardware. There is no way around this. Ideally, audio should be played in the format it is natively in, and if it is going to be resampled, then best results are an even resample multiples. As such, 44.1khz CD Audio should be played at 44.1khz, or resampled to 88.2khz. This *is* possible on the Envy24 series of cards, as they don't resample stuff in hardware. Point to the Envy24.
Are you using analog output, or SPDIF output? If you are using SPDIF output, then this section is irrelevant to you. If you use analog though, then pay attention. The DACs found on the Audigy cards are excellent as a general rule. There may be lower quality DACs on the low-end Audigy 2 or older Audigy 1 cards, but I'm not quite sure off the top of my head. The DACs of the Envy24HT series of cards are also excellent, but I know that the DACs found on the Envy24HT-S cards are average at best. If you look at my recommendation above though, if you are using analog, you should be using an Envy24HT, not an Envy24HT-S. One could probably do alot more research and argue wether one of the contenders has better DACs, but that person isn't me. One thing for certain though is that if you get a regular Audigy 2, or an Envy24HT, then you are getting good analog. No points here, as they are pretty much tied.
Driver quality. Creative is notorious for their horrible drivers, combined with massive bloat on the driver accessory level. This was definitly a large factor for my purchase of a a non-Creative card this time around. The drivers for the Envy24HT-S are absolutely much cleaner than any Creative driver since the excellent AWE64. Even more full featured drivers like the ones for the Envy24HT based Prodigy 7.1 get you alot more (like ASIO support) for a smaller amount of control panels. Point to the Envy24.
Everything else between the cards will be essentially the same. I'm not here to make the decision for you, but this should be enough to make a buying decision based on what you need the card to do.
Originally posted by: dchakrab
I just got this card...never had a nice audio card before.
My computer speakers are THX certified Altec Lansings, with an SPDIF input. I attached the SPDIF out on the card to the SPDIF in on the speakers. I get no sound if i play an mp3 file. I can unplug the SPDIF cable from the speakers and see the cool red light, so I'm assuming the port is live, the drivers are happy, and the SPDIF is working, for some definition of working.
Do I need a digital or other connector running from my CD player to the card?
What else could the problem be? Can I use SPDIF for everything (mp3's, etc) or just for DVD's, with a connector cable running from the DVD drive to the audio card? I can't find any connectors for drive->card, so I'm going to have to hunt around.
I can connect the card with the analog connectors, but only one connector seems to be producing anything (the green line out connector) ...the others seem to do nothing. With my speakers in ProLogic mode, it still sounds great to my untutored ears, but...?
Thanks,
Dave.
