I'm planning to get an Asus A8V in the near future. There are three fan connectors on this board. They are called PWR_FAN, CPU_FAN, and CHA_FAN. CPU_FAN is obviously for the CPU fan. I'm pretty sure that PWR_FAN is to monitor the fan in the power supply. Now, the other connector, CHA_FAN, is located on the bottom right portion of the mother board(assuming the motherboard is installed in the case and you're staring at it through a clear plastic side case door). Since most cases need a rear chassis fan I would assume that anything called CHA_FAN would be connected to the rear chassis fan. On the other hand the location of this connector is very near the front chassis fan. Do I connect CHA_FAN to the rear chassis fan or the front chassis fan?
