Jeff7181
Originally posted by: Pollock
Using your finger isn't a very good idea. Dead skin cells fall off and hamper heat transfer (or so says Arctic Silver).Originally posted by: Gamingphreek
Well you should use even less than that rice sized amount. Also spread it around evenly with your finger instead of the HS as when the heatsink is shoved down some could be pushed off of the core and you could have an uneven contact as well.
AS5 is supposed to be better (though slightly) than ceramique.
-Kevin
Not to mention your body oils contaminating it.
