OrangeParktech
I just swapped from Ceramique to AS5. I burned it in the same way as before, and i seem to have risen a few degrees, rather than drop the few degrees i was suppose to.
Any ideas?
Any ideas?
Originally posted by: Budman
I prefer Ceramique myself, IMO it's just as good as AS and much easier to clean up.
You told me a couple years ago I wouldn't see more than a degree or 2 differences between T.I.M.s and of course you were right :beer:Originally posted by: THUGSROOK
Originally posted by: dguy6789
You must have applied it wrong, as AS5 is MILES ahead of ceramique. Just put a small drop on the center of the heatspreader and that is all. No big globs.
Originally posted by: OrangeParktech
it was done right. Small grain of rice sized pellet right in the center, use heatsink pressure to spread it into a nice round circle across the center, etc, etc.. Thats what was done.
I do this stuff for a living. I just never switched to AS5 until now.
Its not that my temps are bad by any means, its just that they are a few degrees worse than before. I didnt know if this stuff needed alot more time to burn in than the ceramique or what. My ceramique was giving me 3c better than this on idle after the exact same amount of time. As far as i know, they both had the same burn in time for full conductivity. And i must say, as of right now, ceramique is kicking AS5's AS5, if you catch my drift 🙂
Using your finger isn't a very good idea. Dead skin cells fall off and hamper heat transfer (or so says Arctic Silver).Originally posted by: Gamingphreek
Well you should use even less than that rice sized amount. Also spread it around evenly with your finger instead of the HS as when the heatsink is shoved down some could be pushed off of the core and you could have an uneven contact as well.
AS5 is supposed to be better (though slightly) than ceramique.
-Kevin
