CD Audio extraction speed?
Jeff7181
18,368
11
Just wondering what a normal speed is to extract audio tracks from a CD to wav format. Right now my drive is going at about 8X... seems a little slow to me.
Jeff7181
18,368
11
Wonder if it would be faster to copy the .cda tracks to the hard drive, then convert to MP3 format (which is what I want them in)
ElFenix
102,402
8,574
.cda is just a placeholder for windows, its not the actual sound file
Sid59
11,879
speeds depends on method you use to extract and software.
Waay back on 98se, i used a vxd.dll patch and it showed all the wavs. Just copy and cut from the cd.
Smbu
2,403
It depends on what type of drive you have. If you have a cheapy one then most likely the extraction speed will not be very good. Some drives are just really good at ripping cd's. The drive I am using is an old Plextor 12x10x32 scsi drive(from 2000) and it rips cd's pretty well. cd extraction is usually in 16x-32x range(from the start of the disc to the end of the disc). So it just depends on the drive really.
NesuD
Liteon cdrom and dvdrom drives are particularly good at cd audio extraction. I think i could classify them as cheapie drives.
Link to cd/dvd rom speed test results check the link I think you will see that the very inexpensive liteons are among the fastest at DAE.
Sid59
11,879
do you know what software and what method they used to DAE? Cause those are fast speeds and i cant get any of those EAC speeds in secure mode. Within EAC Secure, my plextor 4012A ripped faster than the Liteon 401252 drive i borrowed.
NesuD
they used an application called cdspeed. which is now called nero cd speed and is bundled with Nero burning rom.
Smbu
2,403
What I meant by cheapie cd drives are those like no label ones you see on pricewatch, or like generic clearance ones at computer stores. I already knew Liteon drives were good at CDAE too.:p
Confused
14,166
Using EAC you will always get a slower speed, as it reads it at least twice. Using my NEC DVD-ROM drive, i get about 10x in EAC, but using other programs, such as Easy CD-DA Extracter, it will go from about 25-40x, but then there is the tradeoff in that it's nowhere as accurate and good as EAC :)
Confused
