Question Case USB-C
I’m sort of confused about front usb-c ports on cases. Do they need to go into a usb-c motherboard header which I’ve yet to find on any motherboard *I haven’t shopped the ultra high end* or does the front usb-c plug into one for the motherboards 3.whatever header?
Edit: appears it needs to into a usb 3.1 gen 2 header, I assume a usb 3.2 header will work.
usb type c headers are different then your standard headers.
They look like this:
and yes typically higher end boards will have a type c header port which should not be confused with a standard 3.0 header.
Looks like I’ll have a non functional usb c connection on my case.
Sort of irritating I have 2 usb 3.0 case connections for two usb 3.2 motherboard headers and zero usb c connections on the motherboard
2 fast motherboard headers slowed by case connections
1 super fast super high power connection on case that can’t be used by motherboard.
Oh well I still have the back ports
check your board again.
If your board has a type C in the rear, there is a good chance it will have a type C header.
They look like this on the board:
oh... the case....
Its most likely a fake type C.
Meaning its a usb3.0 adapter to type C and not a true 3.1 type C.
oh... the case....
I haven’t bought the motherboard yet but it appears the Asrock X570 steel Legend does not have a usb c header. That’s okay, I can deal with it honestly other than plugging a thumb drive in or usb headset I tropically don’t use the front usb.
Just irritating
@aigomorla Two things
First I assume it is safe to plug a case USB 3.0 into a motherboard USB 3.2 header, other than there being less speed there is no concern correct?
Second I figured out the USB-C thing on asrocks steel legend, asrock sells an add on PCIE card to add USB-C with I think 36 watts of power.
first... yes, if the header looks like a standard 3.0 header, then yea its fine.
second... that is probably a thunderbolt addon card and not a 3.1 card.
thunderbolt is another can of worms.
