Case speaker connection
sterling
Banned
Sep 18, 2002
445
HI
I bought a antec case. It has a 4 pin speaker connection and I was wondering where it is supposed to go?? I dont see any connections on the motherboard. Was I supposed to buy a small case speaker? I have a 865perll motherboard.
thanks
tracerbullet
1,661
19
(Probably could have kept the questions in one thread)
If the case came with a speaker connector, then somewhere in there is a speaker. They don't have to be very big so it may be hard to see.
Most mobo's do have a speaker connection, unless one is already built into the board. What board do you have?
sterling
Banned
Sep 18, 2002
445
HI
Well there is a speaker on my intel 865 perll motherboard. Must be there for motherboards without built in speaker.
RockV
29
The speaker connection is located at the rear of the motherboard between slots 2 and 3 according to the manual.
