hello
http://www.thermaltake.com/products/cases/6000a.htm
this is the case i purchased about a month ago, and i runs great. the case fans are quiet, and i like it. working on it is kind of a hassle, but not 2 bad. almost everything on the inside is easy to remove. (i'm currently in the process of painting it)
if you plan on painting it tho, since it's all aluminum, you have to prime it 4 or 5 times to make it look good. the case is kinda heavy once you get everything in there, so a geargrip is a necessity. there's a firewire cable that runs through the case, and 2 usb ports in the front, both of which i took out cause they were worthless. the temp monitor came with a bad battery, so i had to replace it.
besides that, i haven't had any trouble with it. the case in general is good for cooling, and i like it. after some mods, it looks PiMp. i took the fan that came in the window out, and replaced it with a led light, i put a red cathode light in, above the window. the case allows for many places to tuck your cables in, so their not visable. i wrapped mine, and messed around with placement. it looks pretty good now, i wish i had a pic to show you.
anyways, i like the case, and i hope you have good results with yout decision.
