Originally posted by: GalvanizedYankee
I will no longer post in modding, lapping or tooling threads because there is far too many inexperianced know-it-alls crapping in threads of this type.
Google is your friend.
...Galvanized
Originally posted by: Zepper
Dremel, drill, nibbler tool, hole saws in the popular fan sizes. That's about it.
I'm just the opposite and am into cooler computers and lots of fans. 😀 But I have moved on to highly efficient fans with low sound output... in fact I just ordered two new fans... a 120mm 78CFM 21dBA intake fan and a slightly noisier 92mm 63.40CFM 39.5dBA that will exhaust out the back. I have 4 80mm fans inside my case too but they are low speed and quiet.Originally posted by: Zap
I use all the above except for hole saws. Haven't done my own fan holes yet. I'm into quiet computers and the fewer fans, the better. 😉
Yep, the 120mm is a Thermaltake. The Thermaltake spec is kinda hard to believe because it is so powerful and yet makes the least noise.Originally posted by: Zap
Sounds like the specs on some Thermaltake fan.
I used to have a couple of Gamma 28 fans from Radio Shack. Those were pretty neat.
