Wasnt sure where to post this, but this seemed as good as any
I bought the Corsair R500 case and have built up my first pc. The front 2 120mm fans and the side 200mm fan aren't working for some reason. I have read that the 3 fans all work together from the same connection, but i cant get them working. The group of cables that is rooted to the front panel has a connection for the side fan, but even after connecting it it isnt running, nor the 2 front fans. Also the 2 front fans are connected to each other, and their wire heads up into what looks like the front panel where the fan button is. There is only 1 button so that makes me think even more the 3 are connected together from that single button.
The LEDs are not working either, so maybe i was supposed to connect the front panel up but didnt? but saying that the power button works and lights up soo... im not really sure
I also read that the corsair fans are specific 3 pin connections that you wont find elsewhere like the mobo, which i have a z77 d3h just so you know, so im assuming that the 3 pin connector i put it in is correct. Maybe they are not connected properly at the front panel or something? I havent looked because its hard to get too and dont totally know what im doing hehe.
Any help would be greatly appreciated
