One of the case fan (80mm, can't use a 120mm) is causing noise, although when I leave the fan outside by itself, I don't notice noise at all. So, I think the vibration is causing the (thin) metal of the case to vibrate...its like a whiny noise. Anything I can use to reduce or eliminate this noise? So far, I have found anti-vibration gasket and some washers, but I am not sure what is best to use. Links to items would be great!
