I currently have one case fan in the front, and one fan in the rear. They are both positioned so that it will suck the air out of the case. I figured they will suck air in from the holes on the side of the case, and this will be sufficient. Should I turn the front fan around so that it will suck air in to the case and the rear one will suck it out?? Is this better for cooling? If so, is there a way to prevent tooo much dust from coming into the case from the front fan??
Thank you.
slim
Thank you.
slim
