Caring for a turbocharged car
Doggiedog
12,780
Hi All,
I've ordered a turbocharged car and have never owned one before. Is there any special care I should be aware of with it? I will own it so I would like to have it last as long as possible.
Thanks!
EightySix Four
5,122
52
What car?
Newer turbo cars have about the same maintenance requirements.
Be a little more careful letting it warm up and cool down since the for a turbo warm=surface of the sun hot, so don't ride it's ass all the way to the parking spot then just turn it off.
Arkaign
20,736
1,379
Many turbo cars recommend warm-up/cool-down periods. My old VR-4 had a statement in the manual relating to that. There are even cool-down timers available for some configurations.
We really can't say without more info though.
EightySix Four
5,122
52
Originally posted by: Doggiedog
Originally posted by: nkgreen
What car?
2009 BMW 335i
I should get it in 6 weeks.
Let it cool a bit before you park it if you spool them up heavy. Otherwise there should be no difference.
Don't forget Dinan can bring that sucker up to 380hp/440lb.ft torque with a simple (warrantied) flash ;)
Arkaign
20,736
1,379
From what I've heard, the 335i turbos are low-boost and well cooled, so special emphasis is probably not needed for a cooldown period.
Doggiedog
12,780
What car?
2009 BMW 335i
I will need to investigate this. :D
CRXican
9,062
lol it's a BMW
you think the average owners pay attention to cool down?
don't worry about it
nakedfrog
62,785
18,982
Originally posted by: Possessed Freak
If you spool up the turbo, make sure you idle/run normal for 5+ minutes before turning it off.
Five minutes? :Q
That seems excessive.
halik
25,696
Umm no. Unless you've been bouncing off the redline for the last 10mins, you don't have to do that...
Just make sure you use synthetic oil and don't hit the boost hard until the car warms up a bit.
exdeath
13,679
10
Keep up with engine oil and filter maintenance religiously. It's the lifeblood of the turbo bearings, more so than the engine itself as is often the case.
Gand1
1,026
Five minutes? :Q
5 mins is waaay excessive... my TT has no turbo timer but depending on how hard I drive it I let it idle from 30 seconds to a few minutes tops.
RGUN
1,007
Five minutes? :Q
There is no need for a cool down period on modern turbocharged cars for street use. They are both oil and coolant cooled, and the system is setup in such a way that when you shut the car off, the coolant continues to circulate until the temperature of the turbo no longer heats up the fluid.
Turbo timers, or cool down periods are a waste of gas period.
*edit* to add a few other points. Make sure you use the best fuel available to you. If you ever have to run a lower grade fuel, be sure to stay out of boost! (does this car come equipped with a boost gauge?). As stated earlier, do not slide on the oil change frequency.
If you start adding power than you will also need to change the plugs every 3rd oil change or so - dont get fancy, go with coppers or whatever your manual recommends.
Do not make any modifications without looking into engine management requirements.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Five minutes? :Q
Winner.
With the advent of water-cooled turbos, the requirement for a "cool down period" has essentially disappeared. On older cars that do not have water-cooled turbos, it is still a good idea to give the car a few minutes to cool down, but a 335 will certainly have water cooling for the turbos. Even with the engine off, coolant will continue to circulate through the turbos' bearing housings, either through passive convection (as with my S70's turbo) or via an auxiliary electric coolant pump (as with my 951's turbo).
The only caveat is to never turn the engine off while it is making boost. Always bring the engine back to idle for a couple of seconds (5-10) before shutting the car off. This ensures that the turbo is not still spinning when you turn off the engine. This is a concern because when the engine stops, oil pressure drops to zero and the turbo's bearings will lose some lubrication. In practice, the process of pulling the car into a parking spot or into your garage is long enough for the turbo to spin down so the only thing you really need to avoid is turning the key off when the engine is revving, which most people won't do anyway.
ZV
iamwiz82
30,772
13
did you get the sport package? The early 335i non-sports did not come with oil coolers, IIRC. I am not sur eif they changed that. Dinan does not warranty a car with no oil cooler unless you also buy the Dinan oil cooler along with the flash.
Doggiedog
12,780
Yes. I got the sport package in 6MT.
What about warming up the engine? It's going to be pretty cold this winter. Will I need to warm the car up any more than normal with a turbo or is the requisite 30 secs - 1 min ok?
ayabe
7,449
No, just stay off boost until you're at operating temperature.
RGUN
1,007
Aside from letting the idle stabalize, I try not to let the car sit without moving. Just keep the revs down and out of boost.
rh71
52,844
1,049
did they discount the '09s much now that they're not keeping many in inventory in the states? I know 08s are being heavily discounted with the low finance rate.
grats on the 335i... I really wanted that twin turbo for mine but alas only in the X6 which is fugly... and I definitely didn't want to wait for the TT diesel. :(
EDIT>> I see it's 0.9% rate on the '09s too, but were you able to get them close to invoice? BTW, REALLY jealous of your new idrive. :(
halik
25,696
Five minutes? :Q
Hmm I don't think my Audi has coolant recirc pump, but the turbos are hooked up to both oil and coolant.
