CrystalBay
- Apr 2, 2002
- 2,175
- 1
- 0
Originally posted by: kumanchu
a good seasoning will work very well, even for eggs.
carbon steel seasons fine. i have a couple of those. the main problem with teflon is that the temperatures that you are _supposed_ to be using is higher than what teflon is meant to be heated to. it will burn and flake into your food at the correct temperatures; whereas a properly seasoned wok will not do that. woks are meant to cook at extremely high temperature (basically as hot as you can get it) which is why restaurants and enthusiasts don't use normal stoves to cook on. they just don't get hot enough.
This man Knows what he's talkin about. Teflon at high temp turn toxic and also destroy the finish
High Carbon Steel is where it's at in Woks and Knives....
Season you wok and never use soapy water to clean it out, just use hot water and a not to abrasive scrubber. Otherwise you'll rust.
1. To keep food from sticking after properly seasoning the steel .
2. Heat wok to high temp , than add peanut oil , swirl , add meat , no stick...
Hot pan, add fat , food wont stick.....Cold pan, cold oil ,food will stick
Also gas stoves are almost a must with any wok, tough to do on electric ranges , but can be done in batches.
