I forgot to mention that a few days ago I was in park revving the engine pretty hard (italian tuneup), holding it at 4000rpm for like 30seconds, then idling, and going back up to like 5500rpm and dropping, then holding 2K rpm for awhile. I did that for about five minutes and a bunch of water came out of the tail pipe, mostly on the left and a little on the right. I turned off the engine, then turned it on again and the check engine light went away. I then drove the car 3 days ago, check engine light never came back on and I found it ran a little better but when I hit high load situations, it began to vibrate pretty badly and I couldn't go up hills on the highway very well at all.
So today I drove the car with the new fuel filter in place, and I've found the car to vibrate and or stumble a lot less at idle than it used to, but once I put it in a high load situation such as in drive with the brake partially depressed and the car creeping forward, the car likes to shake pretty badly. Reving the engine to 900 rpm makes it shake, 1700rpm and that's about it, higher RPMs sound and feel fine. I had great difficulty in climbing hills today but I'm still happy as the engine and car does not vibrate as violently as it used to. Before filling up, I did an italian tune up at the gas station for about 5 minutes, a small puddle of water developed below the tail pipe, but nothing like from before. I think I'm on my 3rd tank of new gas, I fill up 3 gallons at a time, running on low. Oh and for those who think it's the fuel pump, the car has yet to die on me or even make me believe that it would die on me.
I'm starting to think the real issue is with the fuel injectors.
