Originally posted by: brblx
don't you have a harness adapter? you should be attaching that to the headunit and plugging it in to your stock harness. there are porbably not any plugs past the one that goes into the back of your stock radio, as the wires start to seperate and run off to different places.
T25's are pretty common nowadays. never seen them on a japanese car, though, usually euros.
thanks brlbx. so looking at this picture,
1) the left wiring came with the new stereo and that's what i would plug in the back of my new sony stereo...
2) the middle and right wirings came from Crutchfield and that's what i would hook up to the wiring in my car...
3) and then i would use the crimper and connecters to connect them all?
4) also, where should i attach the ground (the metal part on the left wiring)? anywhere in the back of the console? can it be metal or should i try to find a non-metal surface. i'm thinking of attaching it using electrical tape... is that OK?
