Car people: Question about tire pressure....
Zenmervolt
Elite member
Oct 22, 2000
24,512
21
As a general rule of thumb, 32 PSI will be safe in almost any passenger car tire.
I typically run 5 PSI over recommendation in front and 2 PSI over recommendation in the rear. This gives me a little more oversteer and makes the car a little more "twitchy" than normal, but that's how I like it.
Run the recommended pressures from the sticker and make adjustments from there.
ZV
kingtas
421
My new tires state 44 PSI and the label on the door panel states 32. The tires always look low with 32 so I put 40 PSI.
When I was younger, I always put the max PSI as per the tire and they always wore even with a comfy ride. As far as safety, I it never gave me trouble and I live in Africa hot weather.
Kaervak
8,460
I usually go 0.5 psi over the MFG spec. 30.5 psi front & 26.5 psi rear.
SVT Cobra
13,264
The tire is max pressure it can withstand...
MulLa
1,755
Mine has a different pressure for "high speed / fully loaded" as to normal driving. I normally have it somewhere in between.
kingtas
421
I never went over the max PSI. And I'm sure the max rating has a safety buffer.
KDOG
14
Well the tires say 44 max and the numbers in the door jam say 30. I'll try it at 35 for awhile...
