car experts
FoBoT
63,084
15
fobot.com
i agree with MIKEMIKE
may your car fall to pieces around you
i award you no points and a bar of soap for your foul mouth
FoBoT
63,084
15
fobot.com
Originally posted by: Fingolfin269
Originally posted by: fire400
how much would the front wheel drive on the sudan run if I they just re-alligned/re-adjusted?
What is a sudan?
Sudan is a country in Africa, most notable for the recent ethnic strife that has left thousands , if not millions of people dead
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Your story would generate a lot more sympathy if you would think before typing such a "dirty" (pun intended) rant.
A better choice of words could convey some education, etc
sao123
12,653
205
Originally posted by: Linflas
Is it possible there is dried packed mud on the insides of the rims? I have had this happen with snow before and oddly enough it didn't just vibrate loose I actually had to remove it from the rims.
You got mud in your tires...
How exactly do you get mud into the tire??
Brutuskend
26,558
4
He said RIMS, not tires. There IS a difference you know....
Ryan
27,519
Rim != Tire.
jemcam
3,676
Alignment problems will not cause a vibration, only tire wear and handling issues.
More than likely you've got mud caked inside the wheels or something. Take it to a carwash and blast the undercarriage and insides of the wheels.
labgeek
2,163
It's pretty obvious! It's PEBSWAS - Problem Exists Between Steering Wheel And Seat.
You are an idiot. Instead of complaining about everyone else that has ZERO responsibility in your stupidity, you should look into the rear view mirror therein lies your problem.
VirginiaDonkey
1,704
OP=fucken Dumbass for even fucken burying the fucken wheel to that fucken point
your fucken answers have been fucken posted alfucken ready.
sao123
12,653
205
Originally posted by: Ryan
Rim != Tire.
:thumbsdown::thumbsdown::thumbsdown:/4
Almost a dumass award to you both... I was quoting My Cousin Vinny.
AdamK47
3,623
I'm going to agree that it's mud on the inside of the rims causing the shaking.
Zolty
3,603
A few more grammar mistakes and you just might be suitable for myspace.
fire400
5,204
21
alright, I did say not to talk about the story and just asked for help, obviously people make mistakes, stupid garage geeks can't get a hold of themselves and just shut the ****** up
yeah I tried the car wash and ordered a deluxe premium package which came with double wash
tried the car, still rattled at over 40mph
went home blasted the hose while the car was jacked up, tried to spray everything I could see , tons of more mud came out even after the car wash.
finally, the dude just said, we can check to see if the wheels will balance out? so if this doesn't work, maybe the mud is so deep it can't possibly be cleaned with a normal hose? otherwise the problem must ly elsewhere in the car.
blahblah99
2,689
Bring your fucken car to your damn mechanic so he can rip you a new asshole, since one isn't doing justice for you.
altonb1
6,432
So what did the mechanic say?
rezinn
2,418
Did no one ask why you were in this ladys lawn in the first place?
As far as your car, don't overlook a bent rim or driveshaft. I guess caked on mud could cause the driveshaft to be balanced incorrectly and cause your problem.
