Car busted (piston shot out the side of the engine)
five40
1,875
Originally posted by: BUTCH1
Originally posted by: eplebnista
Link
That's what I was thinking too, also OP doesn't state if he was driving@ normal Hwy. speeds
or trying to race a Mustang GT when it happened. :)
I was going normal highway speed at the time(70mph)...in chicago limit is 55mph but no one does that speed.
five40
1,875
Originally posted by: compuwiz1
First off, your dealer did not make it, and they did not break it. Therefore, any thoughts of liablility go out the window, as far as they are concerned.
Next step, go after the warranty. Oh, you are expired, I see.
Did you know that an extended warranty would have paid for this problem, had you bought a 7yr / 100,000 plan? Oh, I almost forgot, it's a Toyota, and they never break. ;)
At the time, the extended warranty was 5yr/60k which I did purchase. It did cover a couple of things that break. Any manufacturer is going to make lemons, it's just which ones make the least lemonade, and most of the time toyota makes the least lemonade.
Eli
Super Moderator | Elite Member
8
:thumbsup:
At least you have a clear head and aren't like, "OMGWTFBBQ TOYOTA SUCKS!!!!!!111oneone".:p
SearchMaster
7,791
114
:thumbsup:
Says the man with the Toyota that also threw a rod :D
iamwiz82
30,772
13
If this was a domestic people would be up in arms screaming how it's typical American junk. :confused:
boomerang
18,883
641
I hear ya. I think the imports put something in the air vents that's some form of mind-control. No matter how much goes wrong, breaks, etc., it's still a great car and far better than domestic.
Eli
8
:thumbsup:
What? lol
five40
1,875
For me it's been good track record. In my family there has been 10+ toyotas that have all lasted 150k+. Parents, sister, wife, etc... and this is the first one that has had major problems. If I had a great track record with domestics I'd be buying those.
jagec
24,442
Originally posted by: Kalvin00
People still fall for that 3k miles/3month scam?
Bwahaha.
? Not sure what you mean by that. I probably don't change my oil often enough...more like every 4.5-5 months since I only drive about 600 miles/mon.
That's more than enough.
As for the engine failure...IMHO something had to have gone wrong for it to fail at 77k. IMHO any car worth buying should last to at least 200k. Using different oil wouldn't have caused it, but it makes me wonder if they did anything else while they were under the hood.
Originally posted by: Greenman
or perhaps Toyota's engines just don't last that long. (Never owned a Toyota)
Heh. Quite the opposite.
It's true that people knock on domestics, but I don't think anyone here is claiming that the OP is lying, that Toyotas never break, and so on. Toyotas have a good track record because, for the most part, they make good cars...but they're certainly not bulletproof, and it sounds like this one was a dud.
Eli
8
I'm betting that he drives like a granny. If he had a lead foot, it probably would have chucked its rod at him several tens of thousands of miles ago.
Assuming it was indeed a manufacturing defect. It probably spun a bearing or something.
Regs
16,666
21
My toyota camry ran without oil for at least 6 months before blowing the piston into the crankshaft.
Though I think I was running slick 50 too.
Though I don't know how the wrong oil could blow a rod like that in such short time. Not unless it was 1 part oil and 10,000 parts water.
Gamingphreek
11,679
OP where did the rod shoot through the engine block? If it shot through into where the Oil Pan is (And the hole isn't giant), then it is possible for someone to replace the oil pan and weld a patch where the hole is (Cut a circle and then weld an equally sized circle in its place). After that all that would need to be done is replace the piston rod.
My Toyota Pickup threw a rod (My fault) when I was off-roading (Initial blast of water in the engine) and because of the placement (No pressure above or below where the hole is we are planning on getting someone to weld a patch for us. (It's a shame I have no place to work on this, because I would love to bring the ol' girl back to life myself- though I have little-no experience welding).
Different oil wouldn't have done this, it must have leaked out somehow (Normally if you are low on oil the engine will seize before it comes to this- you must have had her at a mid-high RPM for it to snap the rod).
If the hole is too big or at a bad location- you can buy a new engine block and essentially rebuild the engine, but you would probably be better off just getting a new engine all together (By new I mean from a junk yard or elsewhere).
-Kevin
IGBT
17,976
141
Originally posted by: zoiks
I thought Toyota's run forever.
..big Tundra(Tuba) recall ongoing. Their 5.7L v8 is chewing up cam shafts. All 30K of em have to be replaced.
jagec
24,442
It may have been running with a dry dipstick, but it wasn't running "without oil."
FWIW Slick 50 is snake oil BTW;)
jtvang125
5,399
51
My friend blow out the motor in 2 cars (piston shot out of one and the engine just sieged on the other). Both times he was driving the car like he stole it so there may be more to this story than what the OP is telling.
marincounty
3,227
I can't find any links to a Tundra recall over camshafts. I see that the Detroit Free press thinks they are going to have a recall because of 20 broken camshafts out of 30,000 engines. In cases where a Tundra camshaft fails, Toyota is replacing the engine at no charge. Toyota says it was an early batch provided by a supplier and Toyota is "confident in the production from that point on."
I realize you are a Toyota hater but you need to do better than that.
Greenman
22,359
6,498
150K is not lasting a long time. I've never owned a car that didn't hit 250k.
Sukhoi
15,350
I have heard absolutely nothing about a recall. Prove it IGBT.
Regs
16,666
21
Hah.. I remember that quality time with good ol' dad.
Me: "Hey..dad...my car just stopped on the road"
Dad Pulls up on side the road. First thing he checks was the dip stick. Dust blows off of it
Dad: "I found your problem. You got no oil"
Dad slams fist on the front bumper
five40
1,875
If I had been driving like a bat out of hell I would have mentioned that. I was cruising down the highway at 70mph. If I had been driving like a maniac there would have at least been a reason for a piston shooting out the side of my engine.
iamwiz82
30,772
13
Just because Toyota hasn't recalled them yet doesn't mean they won't. I'm sure it won't matter to you, being fanboys and all, but doing a search for "tundra camshafts" yields a lot of negative publicity. The ONLY reason they haven't yet is the estiamted $150 million bill.
iamwiz82
30,772
13
updated the original post
WTF, two months for a Prius? We got one a few weeks ago and had zero wait. We contacted the dealer on Wednesday, flew down there an picked up the car on Saturday, and we paid way under invoice.
