hanoverphist
not necessarily battery, but low/ weak voltage getting to the starter solenoid. that could be a battery, a connection, weak fuse or anything else battery related. since its been sitting for that long with only a bit of run time, id say its either the battery or the connectors, or both. corrosion on terminals sucks, and if let to its own devices will creep up the cable and foul out where you cant even see it. happened to me on my truck, took forever to figure out it was 2" up the cable from the terminal. i was amazed.
