Yeah, it probably needs to be changed. He'll probably be able to notice the difference.Originally posted by: JulesMaximus
25k miles? I'd change it.
Ideally, you should change it whenever you notice your MPG drop.Originally posted by: bernse
I'd change it every 10K. Cheap insurance. More often if you drive in dusty enviroments (gravel roads, etc).
Originally posted by: daveymark
Does anyone know how to maintain a K&N filter? the car I bought came with one
Originally posted by: edro13
Well, I went down and bought one. I have replaced them in the past, but the screws are so corroded and tight that I can't get them off with a screw driver 🙂 Now where the hell is my socket set 🙁
Milage drops are generally a slow process that you don't notice happening until it's really bad. For what they're worth for most cars, I still say change it every 10K or less.. or every 3 oil changes at least.. but hey, that's just me. 🙂Originally posted by: Eli
Changing your filter too often may not necessarily be a good thing, but shouldn't matter too much as long as your dilligent with your other maintenance.
Not if longevity is your first priority.Originally posted by: bootymac
Get a K&N rechargable drop in panel. Best investment evar
