billandopus
- Dec 29, 1999
- 2,082
- 0
- 0
Originally posted by: yamahaXS
i like window air better than AC air.
I do too unless it's hot!
Originally posted by: vegetation
Originally posted by: Imdmn04
does turning the a/c up to the highest level have more of an impact than turning it to low?
Yes, but the mere fact the compressor is engaged causes a lot of parasitic drag. Main reason why we need to up the car voltage and start using electric powered compressors.
Transfering the parasitic drag from a compressor to the alternator doesn't really solve the problem.
Sure it does when the alternator is already operating on nearly every car I've ever been on. Electric operation is just more efficient rather than running separate accessory drives, but it's hindered with limitations as long as 12v is around.
Originally posted by: ElFenixummm... no, the power used to run the compressor can't just come out of thin air... if you're increasing the electric force you're going to have to increase the drag the alternator makes. and then you won't have the option of turning it off to save mileage.
Originally posted by: glugglug
In city driving the AC will decrease milage dramatically, especially on cars less than 15 years old. (after they changed the type of freon used to one more "environmentally friendly" - yet it has 2.5x the impact on milage/horsepower leached....)
With highway driving it's not such a big hit. But if I'm moving at highway speeds I'd rather get fresh air coming in through the windows than AC.
Nah, they just need to create an alternator with multiple gears it can switch into. High drag when battery needs more charging, low drag at other times.
Originally posted by: WinkOsmosis
The drag varies on depending on the current draw. No need for a gearbox. I don't know what ElFenix is talking about... when the compressor is off, there wouldn't be any drag from it on the alternator.
Originally posted by: TommyVercetti
Quick question, why are ricers always driving with the windows down and an arm out?
Originally posted by: acemcmac
I've always been able to feel a noticable horsepower drop between ac and no ac, between every late model car I've ever driven with it...
volvo v70, subaru legacy, camry, corolla, mustang, dodge caravan... if it takes from horespower... i dunno... but its interesting....
I did a little unscientific experiment with my van in regard to this subject. My data was based off of the real time computer mileage readout. It didn't matter if I had the air on or off, at 78MPH, I got 23MPG on flat roads. It was a calm day and I had the windows up in an Olds Silohette with ~8000 miles and a 3.4L V6. and of course, YMMV
He was talking about the hypothetical electric A/C compressor. The A/C in a car is run with the engine, as we all know.Originally posted by: glugglug
So how come the drain is so pronounced when flipping on the AC, but headlights make no noticable difference?
Originally posted by: Fatdog
Yes, but it's less than driving with all the windows open.
