hi,
i was wondering if it is possible to capture my gameplay from shooters with a box like this:
http://www.trustedreviews.com/Hauppauge-HD-PVR_Peripheral_review
which would be connected with a:
Y Video Splitter DVI - I Male to DVI Female & VGA Female
or the signal coud be capture from my gfx cards second dvi output - does it just output the same signal as the first one?
and in turn with a vga to rgb cable.
both adapters are quite cheap.
the recording machine will be a seperate one to not slow down the main machine.
some questions:
dvi has no inbuild drm right?
quality will be a bit less than the original dvi signal i assume....any ideas if its a bad quality loss?
some questions:
