Can't access 192.168.1.1 for settings on linksys wrt54g
seepy83
2,132
MonKENy - did you try holding the Reset button down for 30 seconds while the router is plugged in/powered up? That should put it back to factory settings. So, if someone (whoever brought it to you) manually configured the network settings and disabled the DHCP server (which is what it sounds like from your descriptions), it would wipe those settings and put it back to factory defaults which should be a 192.168.1.0/24 network, 192.168.1.1 address for the router, etc.
MonKENy
2,026
Yep have done it several times, did the 30-30-30 nothing changed
Then use the one listed as the DHCP server.
there is no DHCP for some reason
ch33zw1z
39,813
20,423
but can you ping it...
The GUI not working could be the side effect of the FW update gone wrong. I had a router that took a power hit, the GUI would no longer work for more than 10-15minutes after a reboot, but everything worked fine. I could ping it, telnet to it (DDWRT installed) and manage via telnet. A PITA for sure, but it still worked.
Your situation is a little different. setting up the Client Bridge may be difficult without GUI access.
edit: You should look into reflashing with TFTP
lopri
13,316
690
This may sound funny but did you guys try different browsers? Make sure to disable every add-ons/extensions.
