HardWarrior
- Jan 26, 2004
- 4,400
- 23
- 81
Originally posted by: Greenman
Whatever.
:laugh: Gee, I expected better from the self-styled Pope of air-cooling (who strangely says that he uses water).
Whatever.
Light-loving spora aren't the only things you have to worry about when deciding on a coolant mixture.
At any rate, straight tap water should never be used without an additive designed to buffer the solution and kill whatever organisms are present.
Not all algae needs light.
If you don't believe me and you have older plumbing, remove the strainer and look into the neck of your kitchen faucet.
I'm sorry, but you're wrong on this.
Non-annodized aluminum blocks are rare today, if you can find one at all. Most loops simply don't have the components that will, by themselves, cause galvanic\parasitic corrosion.
You're right, but we were talking about algae specifically, we weren't talking about types of coolant or anything else.
This would be common sense, woundn't it? I was simply stating that even if you used straight tap water, in the absence of light, algae wouldn't be your problem. That's not to say that it wouldn't cause other biologicals to proliferate and/or cause mineral deposit problems. It was purely hypothetical.
Yes it does. All plants use photosynthesis to convert light and carbon dioxide to grow. All algae and all plants use light in varying degrees to grow and reproduce, without it, they'll die. Simple.
Light can easily permeate inside a faucet a few inches, enough to allow some algae to grow, especially over so many years.
You don't have to apologize because I'm not wrong, you just misunderstood what I meant.
Maybe... but what about copper and brass? What about aluminum heater cores that aren't anodized. Corrosion most certainly can be an issue, depending on what you have in your loop. But that's really not the issue here.
I think you didn't quite understand what I meant in my previous post.
I didn't mean for people to start using tap water in their cooling loops, that would be asenine.
All I meant was that even if you did, without light, algae wouldn't be your problem, that's not to say you wouldn't have other problems.
Obviously, pure distilled water with a 5 to 10% coolant mixture is the best solution for water cooling, it's what I've used for the past four months, and I haven't had any problems.
All I was saying was that, ....
Not to nit-pick, but those are bacteria, not algae. Algae do need light to grow.Originally posted by: HardWarrior
Light-loving spora aren't the only things you have to worry about when deciding on a coolant mixture. At any rate, straight tap water should never be used without an additive designed to buffer the solution and kill whatever organisms are present. Most water pipes are either underground or in walls, as such I think you're inventing a corelation that doesn't exist. Not all algae needs light. If you don't believe me and you have older plumbing, remove the strainer and look into the neck of your kitchen faucet.
Whatever.
Originally posted by: Zebo
You're thinking. With no nutriants to eat bacteria and flora does'nt do so well. I've had the same loop for a year and it's crystal clear... Besides most anti-freeze contains ethylene glycol and a ester, mild bacterialcides... With nothing to "eat" and a harsh enviroment I don't see growth if you use DI water and some dex-cool around 10-20%.
Whatever.
Me thinks you missed my point. I think water cooling is a fine idea, I also think it's often more money and grief than it's worth. Pretty simple really. I did it because it sounded like a fun project, but the only real value it has is that I enjoyed doing it.
Microscopic plant-like organisms that contain chlorophyll. Algae are nourished by carbon dioxide (CO2) and use sunlight to carry out photosynthesis. There are 21,000 known species of algae. The most common pool types and black, blue-green, green and mustard (yellow or drawn). Pink or red-colored algae-like organisms exist but are BACTERIA and NOT ALGAE.
Microscopic single cell plants that grow in water, contains cholorphyll and REQUIRES SUNLIGHT.
Simple rootless plants that grow in SUNLIT waters in relative proportion to the amounts of nutrients available.
No, it wouldn't even approach common sense, at least in terms of what I think you're getting at.
Hypothetical? No, that's not the way you posed the statement, and you know it.
Again, you're wrong. Some forms of algae aren't plant cells at all, but animal cells.
You're grasping at straws here. It would be easier to admit that you were wrong at this point.
Yes you are, you're just too tender to admit it.
Sure I did, what I didn't do was fall for your meatball science class like the greenhorn you thought I was.
True, to some degree. If your case has no lighting in it whatsoever, than algae shouldn't be a problem even with staight water with nothing added. That's why most water pipes are opaque, so light can't pass through them. Algae needs light to grow, without it, no algae. Additives are usually incorporated for their corrosion protection, not nessecarily to prevent algae.
With biologics, right? Then why even mention a pitch-black case at all? Wouldn't it just be easier to buy a dedicated biocide (kills plant AND animal cells) and toss a few drops in?
Obviously? There's no such thing as "pure distilled water." The minute you pop the cap and start pouring you loose anything approaching sterility. What about your loop itself? Unless you run it through an autoclave and assemble your box in a clean-room it's dripping with all sorts of biology, and some of it LOVES the methanol in that mystery "coolant mixture" you mentioned. Again, it's easier to just use a biocide, at least for people who have an idea what they're doing. 4-months huh? Let it run for another 6 and then brag.
Whatever.
"Me thinks you missed my point." That's the pat response in places like this when two people just plain don't agree and one of them wants an easy way out. Sort of like "whatever." Thanks anyway, GM.
I am curious - has anyone actually experienced such growth in a watercooling system? What kind of time frame did you experience for the growth of this stuff? It seems to me that, without a source of food, the growth should be very limited and any growth should die off fairly quickly. All this unless you're pumping wastewater into your system, of course. Maybe watercooling loops aren't as hermetically sealed as I'm picturing them? I'm not trying to say that anyone is wrong (as I am actually pretty sure I am the one who is wrong), just curious as to how this comes about in a real system.
Originally posted by: The Pentium Guy
My friend uses the water from his fish tank for his watercooling thing. I'm surprised the fishies haven't died yet (they're tropical fish I guess?)...... although he said he kept the fishes in there becuase it gives him comapny *rolleyes*
I might even go to a stainless box with a squirel cage blower. Panasonic makes one that is pretty quiet.
Whatever.
Yes it was a pat response, as I have no desire to waste any more time on the subject or you. Is that clear enough? (snip)
Guys, your normal run of the mill algae that you find contaminating your water sources undergo photosynthesis.
They need light. We all know there are aberrations in nature, but those are far and few in between, as well as being rare. It would be totally ridiculous of you to suggest that it's going to happen to enough people running watercooling setups to make a difference.
If we wanted to play theory wars, we could do this ad infinitum. Realistically speaking, if you have a closed case w/ no light YOU WILL NOT GET ANY ALGAE.
I did my masters thesis work on growing bacteria and algae for wastewater treatment, so I am somewhat familiar. Suffice it to say that generally, bacteria smell and algae don't. I spent enough time knee-deep to at least make that distinction.Originally posted by: HardWarrior
If you had an active culture of animal algae, you wouldn't be able to tell the difference. There are MANY types of algae. Some strains even exist in a grey zone between between plant and animal life. It's not as simply as "Light=Algae_No light=No Algae." Remember, google in indeed you friend.
