Do you think I could survey property with this? cheap laser level
I have the telescoping survey rod: rod (not me in the pic)
Originally posted by: mattpegher
Again first pic not working but if your talking about laser levels they are useless outside until dusk.
Again first pic not working but if your talking about laser levels they are useless outside until dusk. Plus what do you want the topo of your property for. If your looking for rough topo, a line level and string should work. Alternately there may be old topo maps of your area done at or before development.
What kind of cheap laser levels are you using? A quality laser level will work in just about any non-precipitating environment if there isn't any interference.
Originally posted by: silverpig
First pic doesn't work.
Originally posted by: SilthDraeth
Uhm, I would think if you knew how to survey, then you could do it. It isn't just about having a ruler, or rod, a laser, and you are set.
got a basic dewalt but it only works inside. Do you know of any particular brand and model that will work outside in bright sun, I could really use it.
Originally posted by: TTM77
ha ha. :thumbsup:
There're lots of ways to measure distance. If u're really willing and really care then there are lots of ways.
Originally posted by: skyking
ed, I am an operating engineer and do all types of construction and grade work. On the job we use lasers and transits, but they are by no means the only methods.
There are myriad ways to do a grade survey and calculation for a '70 distance.
One of the ancient and novel ways to do it invloves filling a garden hose with water. Fill it from the lower elevation to the higher, to ensure that all the bubbles are out of it. Elevate the higher end in a curve until the hose is vertical. you can tape it to a chair leg for example. fill it untill the water comes over the top.
Elevate the lower end at the joint where you have it hooked to the filling hose, until it apeears to be on the same level. unscrew it and tape that end vertically to a ladder or whatever works for your apparent grade change. Raise or lower the hose untill the water appears to be at the same level inside each end. Fill it with a pitcher and adjust. Measure the difference from the end of the hose to the ground for your grade changes. This method will work for any distance you have hose for, and is quite accurate.
I have used purpose-built water levels using clear tubing, a blowgun on the end for a valve, and a 5 gallon container filled with an antifreeze solution for both visiblility and all weather usage. Set the fluid level in the bucket at the desired grade with wedges, clear the hose of bubbles, and open the valve to allow the fluid to equalize. It works under houses, around corners, and many places where a transit or laser is impossible to use.
