can you survey property with a laser level?
dandruff
1,407
call around engg firms or registered surveyors ... if they have a crew idle ... they will do it for $50/hr or less .. they should be done in an hour ... plus u r covered by their EOE ... fwiw .. an architect/ construction amnager here ...
MrPickins
700
$50/crew hr is way cheap around here. I'd say average is closer to $100/hr.
skyking
22,362
5,322
Originally posted by: Abhi
Originally posted by: skyking
ed, I am an operating engineer and do all types of construction and grade work. On the job we use lasers and transits, but they are by no means the only methods.
There are myriad ways to do a grade survey and calculation for a '70 distance.
One of the ancient and novel ways to do it invloves filling a garden hose with water. Fill it from the lower elevation to the higher, to ensure that all the bubbles are out of it. Elevate the higher end in a curve until the hose is vertical. you can tape it to a chair leg for example. fill it untill the water comes over the top.
Elevate the lower end at the joint where you have it hooked to the filling hose, until it apeears to be on the same level. unscrew it and tape that end vertically to a ladder or whatever works for your apparent grade change. Raise or lower the hose untill the water appears to be at the same level inside each end. Fill it with a pitcher and adjust. Measure the difference from the end of the hose to the ground for your grade changes. This method will work for any distance you have hose for, and is quite accurate.
I have used purpose-built water levels using clear tubing, a blowgun on the end for a valve, and a 5 gallon container filled with an antifreeze solution for both visiblility and all weather usage. Set the fluid level in the bucket at the desired grade with wedges, clear the hose of bubbles, and open the valve to allow the fluid to equalize. It works under houses, around corners, and many places where a transit or laser is impossible to use.
Here in India, where lasers levels are not so common .... the water-leveling method is standard for small constructions...
P.s. Try getting a transparent Silicone Rubber Pipe/Hose. It will work for all weather conditions and will provide excellent visibility.
That is what we used on the setup with antifreeze in it. Easy to spot the bubbles and eliminate them.
bctbct
4,868
Clear plastic tubing, washer fluid, and you have a water level. Rumored to have been used by the Egyptians, probably not the same materials though.
edit
you can buy a water level that is easier to use by yourself. Takes a while to learn how to manuever without spilling the liquid.
bctbct
4,868
never used this kind but it looks pretty good
text
this is what I had in mind. use blue washer fluid. bad reviews but I think they didnt know how to use it.
Text
