So when you connect another length of wire, shorting the two ends, the field in the new piece of wire as well as the force on the electrons in the new piece of wire, is equally due to the two regions of net charge indicated in yellow.
This is only true of conductors with plentiful free electrons. In that case, even at the positive terminal, the primary acting force is still the excess of electrons in the second piece of wire compared to the first.
In cases where excess electrons are not so plentiful (very small interconnects or semiconductors), the positive end will show a significantly weaker force than the negative end. In either case, it is the difference in electrons that creates the force.
This is a bit of topic and it is a question to all of you people in general, but how would the picture of swivelguy2 look like when the material of the wire is in a super conductive state ?
Because if i assume correct in normal resistance behaviour, if i take a piece of wire and connect 1 side to a source of excess electrons and the other side of the wire to a drain ( do not know a better formulation
🙁 ) where the electrons are depleted, then the excess electrons would flow through the wire but if you would look at the distribution of electrons this will look like the picture, yes ?
Here is the primary question and related secondary questions :
Let's assume the wire is made from a material that is in the super conductive state. All following questions are about the wire while in super conductive state unless noted other wise. Just to nullify confusion.
Now how would that distribution of electrons look like during super conduction ? Because i do not know how it is measured that the electric currents keep on flowing in the wire after the 2 ends are connected with each other directly. This experiment has been done if i recall correctly for 2 years. The current kept on flowing for 2 years until somebody by accident cut the power of the cooling unit to keep the wire cold enough. At least that is what i know.
Here is the idea :
But i would assume that if i would connect the 2 ends correctly, the flow of electrons would be from the side with excess electrons to the side of depleted electrons directly through the connection i just made. That is, if it is for the electrons easier to go through the connection directly. But something tells me that it is not going to make a difference. The current will flow through the wire from the excess electrons end to the depleted electrons end. Why ?
If the ends are connected, the electrons will just flow through the wire because the superconducting state was created before the 2 ends are connected and the current was already flowing. Because of this, the whole lattice structure is set up to let the current flow from the excess end to the depleted end as perfect as possible. With the flowing of current, the formation of the lattice is already fixed
because of the direction of the flow of current prior and during the transition. This would mean that AC current will not flow properly through a superconductor. If this is true, then superconductors are natural rectifiers. Maybe i am wrong and you people can help me out a bit. Because either way, i learn something new.
This is based on what i know for so far. What i know so far is related to the questions i now write :
What is exactly going on ?
Is the electron distribution diagram not correct ?
Does the whole concept of electron distribution not apply in the wire while super conducting ?
I know of superconducting electromagnets fed by a dc current.
Are there also superconducting coils and transformers made ?
I know of the effect of external magnetic fields and the breakdown of the superconducting state. But there are also materials created that where the super conduction does not breakdown from external magnetic fields. Are there experimentally coils created with this material ?
Is a superconductor ever connected to an alternating current before the super conducting state was achieved ? What where the results ?
because i always read about dc currents and never about alternating currents with respect to super conducting materials.
EDIT:
1 extra question, is the wire ever set up to be super conducting and then after the transition, the current is applied ? What where the results ?
Is the current ever reversed after the experiment ? What where the results ?
If reversion of the current over a period of time does not have an effect, i would think it has some measurable effect for a very short time when the current is reversed. I would think of a future use of an oscillating effect because for a short time the lattice needs to adjust to the reversal of the current. This causes some time delay that can be used in an oscillator. That is, if the superconductor really has to adjust it's lattice to the flow of electrons when in superconducting state.
The reason why i think of this, is that it is the reduction of temperature or the increase of pressure on the material that forces the super conductive state. In general, forcing the alignment of the direction of movement from the individual atoms in the material, in effect synchronizing with each other. It is not really the case but the superconductor would vibrate like 1 big atom. Possible even in 1 direction. only x, only y, only z.
And the electron flow shapes the lattice also. Under normal conditions, the electrons do not have much effect on the lattice formation because of the vibration of the nuclei with electrons: the atoms themselves. And since the nuclei have so much more "mass", they are dominant.
But when it gets very cold or the pressure really high, the influence of the electrons increase to a point where the electrons can have a significant effect on the vibration of the nuclei.
But maybe i am wrong , since all this is based on what i know and can be wrong.
I found some information but it is not making anything clear :
http://www.wtec.org/loyola/scpa/03_05.htm
Serious interest in superconducting transformers began in the early 1960s as reliable low temperature superconductors based on Nb-Ti and Nb3Sn became available. Analysis of the feasibility of such LTS transformers concluded that the high refrigeration loads required to keep the LTS materials at 4.2 K made the LTS transformers uneconomical. A major reduction in refrigeration costs and/or the discovery of materials that superconduct at much higher temperatures would be required to improve the economic attractiveness of these electric power applications. In the mid-1970s Westinghouse conducted an exhaustive design study of a 1,000 MVA, 550/22 kV generator step-up unit; it found that current transfer, overcurrent operation, and protection remained persistent problems.
Since 1980, development of LTS transformers has been conducted primarily by ABB and GEC-Alsthom in Europe and by various utilities, industries, and universities in Japan. Advances in production of long-length ultrafine multifilamentary Nb-Ti conductor and high resistivity Cu-Ni matrix materials have assisted in the reduction of ac losses. Feasibility of weight reduction and higher efficiencies has been demonstrated on smaller devices with ratings smaller than 100 kVA: single-phase 80 kVA (Alsthom), 30 kVA (Toshiba), and a three-phase 40 kVA (Osaka University). Larger units have also been constructed and tested successfully. A single-phase 330 kVA transformer built by ABB included provisions for fault-current limiting and quench protection. Kansai Electric Power Company reported the development of an LTS transformer utilizing Nb3Sn conductor. One phase of this three-phase 2,000 kVA unit operated at 1,379 kVA without quenching and transferred fault current to parallel coils under quench condition.
ANOTHER EDIT :
Superconducting transformers seem to exist.
Thus no rectifying is happening in the long run. But i am interested in the maximum frequency of the ac current these superconductors can allow, because i still think there is a small delay (can be seen as phase increase between the secondary and primary coils if it exists )and that delay or phase increase would increase with the length of the material. But it would be very small when compared to the delay(phase shift electrical energy to magnetic energy to electrical energy) from material the core is made from. How do the engineers deal with the eddy currents inside the core material in these types of transformers ? I would think extra cooling.
http://www.abb.com/cawp/seitp202/c1256c290031524bc12567310024e1ca.aspx
