- Jul 19, 2001
- 38,572
- 2
- 91
Link to PDF with Specs
I need to figure out what size hole I need for the two screw holes on the front panel.
The diagram marks the hole as CL, but CL itself is never defined (is this a definition that I should already know? - i.e. a standard size?)
The first pic shows 0.140 R, but I'm not sure if its pointing to the hole itself, or the surrounding material in the molded polycarbonate diagram.
