Originally posted by: kermalou
it's for religious reasons. the local temple wants to put speakers, but they cannot use electricity (no electricity can be used on the Sabbath).Originally posted by: flot LOL, ok I'm curious, is the no electricity thing for some bizarre scientific reason or for some bizarre religious reason? You can't drive speakers without electricity... what would make them move in and out?? Your only option to create sound without electricity is to find another way of moving air, but there's no way to modulate it fast enough w/out some sort of eletrical power somewhere in the path. You can surely put the speakers physically outside the room and provide a way for sound to get IN.. but I have a feeling this isn't what you're looking for.
There is always a loophole.Originally posted by: kermalou
Good idea. You guys have a ram's horn lying around, don't you? I thought every temple had a ram's horn somewhere.Originally posted by: Zebo
You need a mechanical horn like on a old victrola. Google it. Mechanical horn speakers.
See what I mean about loopholes?This prohibition extends to electric sound- producing instrument such as radio, telephone, microphone, loudspeaker, intercom, earphone and hearing aids that produce sounds intelligible to the ear. This prohibition does not apply to a hearing aid that works on the bone induction method where the sound itself is heard only as unwanted noise but when these vibrations are applied to a specific bone in the ear they are then understood as speech. This type of sound was never forbidden. Furthermore, we have no grounds to forbid it on the basis that we suspect that perhaps he may fix it if it breaks. The reason is that there is a only a remote probability that it will break specifically on the Sabbath and even if it does happen, it can only be repaired at the factory.
Originally posted by: Talon
Also do research on fluidic amplifiers. Here is a starting point.
The use of an electrically-powered air pump is per- missible as long as the system is turned on before the Sabbath
