Can someone please explain to me how water can be 350 degrees?
PlasmaBomb
11,636
You could repeat that experiment 1000 times and odds are, it wouldn't happen again. However, if you heated the water once in the microwave, allowed it to cool, then heated it again, the odds significantly increase of that happening.
Maybe they had rehearsed it earlier...
^ The reason being, if anyone was wondering, is heating and cooling the water reduces the quantity of dissolved gases present in the water which can act as nucleation sites for bubbles (boiling).
Mar 10, 2005
14,647
I don't like you...
The thing that got me thinking about this was an episode of Modern Marvels. They were making huge dump truck tires and were pouring 350 degree water on the rubber to get some chemical reaction to happen. It indeed was under pressure. I never knew that pressure upped the boiling point like that.
Thanks for increasing my ever decreasing knowledge ATOT!
they could have used an additive to increase the boiling point, like using salt with pasta.
Locut0s
22,205
43
I believe it has somehting to do with removing impurities or something. I know that this usually only hapanes with pure distilled water. I think it has to do with a lack of nucleation sites for bubbles to form. Someone want to refute or confirm this?
Acanthus
19,915
ostif.org
Water boils at 212 degrees at sea level.
Less at higher altitudes where pressure is lower, or in any sort of vacuum.
More with any compression or source of high pressure. See deep ocean thermal vents.
SKORPI0
18,471
2,411
:awe:
LTC8K6
28,520
1,575
If you ever camped out at altitude, you'll remember that water boils at a lower temperature. So it follows that it would boil at a higher temperature at a higher pressure.
Race cars often run a high pressure cooling system for this very reason.
Howard
47,982
11
Don't all modern cars run a (usually) high pressure cooling system?
Fenixgoon
33,055
12,448
I thought it turned to steam at 212 degrees?
depends on the pressure. if you increase the pressure, you also increase the boiling point (this is how pressure cookers work).
here's the phase diagram for water: phase diagram
temperature is on the X axis and pressure is on the Y axis. S, L, V mean solid/liquid/vapor.
if you start at ~0,0, you are in the solid field
if you increase temperature to ~200K (go only horizontal), water will turn from solid (ice) to vapor (steam), known as sublimation.
now if you increase the pressure at ~200K (going only up), the vapor becomes solid again.
let's say we take the pressure all the way to 10^6 Pa at 200K.
Now let's increase the temperature while keeping pressure constant. Once we hit about ~275K, the water becomes liquid. If we continue increasing temperature, water will turn to vapor (steam). But at 10^6 Pa, boiling doesn't occur until ~475K, or about 200C.
One way to vaporize things that melt at very high temperatures (any metal basically) is to reduce the pressure, which then lets you boil at a much lower temperature than would otherwise be possible.
herm0016
8,510
1,122
i originally came to post the lyrics to "under pressure" by queen.......
BoomerD
65,907
14,308
Duh...you have to heat it twice...maybe 3 times. You just can't get it that hot heating it once...
:p
blinblue
889
You never mentioned your units. 350 Kevin is a nice hot 76.85 C or 170.33 F. Also, what everyone else has said
lupi
32,539
260
Have you never seen it raining when temperature was below 32.
Have you never seen details about a steam engine or even modern nuclear plants.
Even a little tea kettle will have water inside over the boiling point.
JEDIYoda
33,986
3,321
OP never took junior high chemistry?
Sure in Jr High You learn the boiling point of various liquids.
But depending on the teacher and such you may never get further into what this subject is about!!
Also - there always one in the crowd-- OP never took Jr High Chemistry......sad
