Can someone help me with my Xbox.
randomlinh
linh.wordpress.com
i have the xecuter 2.6, i don't have any problems.. but i'm using mine more of a media box anyway. I have to say tho.. I find the solderless adapters to just suck. I bought it because I'm lazy. But in the end, I trashed it and just soldered the damn thing on.
jamesbond007
5,280
Yep, solderless = mixed bag. I had a few friends that bought into the solderless chips when they were first coming out. Over time, the connections weren't so snug and the chip had to be repositioned due to the Xboxes being transported over time to each other's houses.
I've got an Xecuter 2.6 (soldered) as well and it's been a flawless mod. My Xbox is by far my most-used electronics equipment I've ever purchased and I wouldn't trade it for anything!
AdamSnow
5,736
You supply the hard drive and chip... pay for shipping (Since you don't live in Ontario) and I'll solder it all together and install the software for you for free...
purbeast0
53,664
6,547
dude that is a major rip off. where do you live?
also, get an xecutor2. the 3's have some more features, but to most people they are useless. if the 2 is cheaper I'd say go with the 2. i've had a 2.6 for ages and it works great. also go with a soldered chip.
necro007
1,002
First off thanks for all the replies and help you guys are giving me...
Well i do no how to solder, i built myself a 40W RMS AMP (it was a school project, and it worked), its just that i don't know anything about the mod chips(i know what they do),just don't know about the diagrams for them and where to get the bios or about thouse dashboards, how do they work?
Like how do you do a setup, what is a good mod chip,ect...
Thats why i thought it would be more better if i could get it mod'd for me.
I have tried reading the stuff here but its does not make any sense .
The reason i want to mod my Xbox is cause i am going to South Africa right now i'm in Canada, and i will be studying there.
They use PAL where as over at Canada they use NTSC so someone here told me that if i mod my Xbox i would be able to change the video output to PAL and it would work on a PAL tv(i hope thats true:confused;).
Also if i do go and get some games from any where(like Japan or the US or anywhere) i was told i will be able to play them.
Another reason was that i would be able to save my games to my Hard drive so i won't have to use my disks, cause one of my games don't work any more...its got a very slight scratch:|, i think these Xbox disks are just too weak....anyway...
So waht do you think i should do, any help would be great.
Oooo by the way they have a dif power output it is:
South Afirca: 220V and 50 Hz compared to Canada's : 110V and 60 Hz.
I thiught i would just buy a transformer, do you think that it would work?
I saw one at London Drugs for about.......$30-$50 Can...it will step down the voltage for me.
Any idea's what i could do?
evetstech
284
If you're getting an xecuter based mod chip, they have direct diagrams on where to solder, and what they are for. I have an x3, and I like the added features, but if you are tight on money, get the x2. I have a 80gb HD on mine, and still haven't filled it up (I mostly put roms and use it as a media center). As for the bios and dashboard, you get them from "a place" on irc, they have guides. As for the dashboard, the easiest way to explain it is when you turn your xbox on with no disc in it, you know that menu interface you see? That is the official xbox dashboard. When you install other dashboards, they give you more options and features (like running a game off your hd, running programs, etc). There is an ultimate setup disk that someone made in where they have pretty much all of the popular programs, dashboards, etc, and a bunch of other added features like formating your hd, etc... Another thing, why South Africa?
Edit:
Originally posted by: purbeast0
1. Get the 2.6CE chip for $34.99. and install it.
2. Find a HDD here or here.
3. Find the "Slayers Auto Install" disk online somewhere. It contains an auto install for evolution-x and will also setup your newly upgraded hard drive and format it correctly.
4. ...
5. PROFIT!
Reminds me of the underpants knomes
1. Steal underpants
2.???
3. Profit!
necro007
1,002
Thats my home town, i move'd to canada last year June so i will be going back there, so i just want to make sure that my Xbox will work there.
Edit:
evetstech what extra feature's does the X3 have over the X2?
By the way i'm not tight for cash i just want a chip that will do everything i want it to do.
necro007
1,002
Originally posted by: necro007
bump..help
what more help do you want?
Well i still need help with the power and video problem.
Edit:Well i have been thinking if you guys say that to install the X2 chip is not hard and setup is easy then maybe i will do it my self.
This is what i found:
Part1-Seagate 160GB 5400RPM IDE Hard Drive- Thats the largest Hard Drivei could find that is 5400RPM, also all you guys that have larger hard drives like 300 and 500 Gigs how is the heat it gives off inside your Xbox?
Part2-Xecuter 2.6 CE
And as for the BIOS and dashboard i don't know where to get that from, which one is the best.
Also i'm looking for a dashboard(am i right by saying that xbox media center is a dashboard) that will be able to allow me to:
1... store my games on my Hard Drive
2... Be able to transfer files to and from Xbox to PC
3... Play movies without buying that Xbox remote
4... Play emulators
5... play my mp3's
6... well thats it.
What would you recomend.
What would you guys recomend?
Would you change anything?
purbeast0
53,664
6,547
4. ...
5. PROFIT!
just do that you will be set. slayers has a dash (evolution X) and it installs all that crap w/the push of 1 button. even a n00b like yourself will be able to set it up after you have formatted your new HDD.
formatting your new HDD w/the new dash and all of these other apps is just 1 button push.
TheSiege
3,918
14
ive charged 50USD and 75USD a couple times but nothing more ever, anything more then that is a rip off
Cabages
2,918
Ive just modded mine with a softmod. Free and cheap. 160 GB hardrive. XBMC is the best.
Ive charged $80 for a softmod and new HDD (HDD not included) before.
necro007
1,002
Guys please answer these questions:
1...Where can i get the diagrams for the X2 chip i can't find it.
They use PAL where as over at Canada they use NTSC so someone here told me that if i mod my Xbox i would be able to change the video output to PAL and it would work on a PAL tv(i hope thats true:confused:.
Another reason was that i would be able to save my games to my Hard drive so i won't have to use my disks, cause one of my games don't work any more...its got a very slight scratch, i think these Xbox disks are just too weak....anyway...
2...Any idea's what i could do about the power and Ntsc problem?
Well i have been thinking if you guys say that to install the X2 chip is not hard and setup is easy then i will do it myself.
3...also all you guys that have larger hard drives like 300 and 500 Gigs how is the heat it gives off inside your Xbox?
4...And as for the BIOS and dashboard i don't know where to get that from, which one is the best.
5...Also i'm looking for a dashboard(am i right by saying that xbox media center is a dashboard) that will be able to allow me to:
5.1... store my games on my Hard Drive
5.2... Be able to transfer files to and from Xbox to PC
5.3... Play movies without buying that Xbox remote
5.4... Play emulators
5.5... play my mp3's
5.6... well thats it.
6...What would you recomend, can i get the drive for cheaper.
7...Is this that slayer ?thing?, which one do i get? And is that slayer program the same auto thing you guys were talking about, does it setup my hard drives, and comes with a dashboard?
Sorry if i'm annoying you but i just want too be sure here.
TheSiege
3,918
14
#xbins and #xbins-help on efnet, there is a prog that will switch from ntsc to pal i dunno about the power, #xbins has an ftp for dashes and bioses and proggys
forums.xbox-scene.com is your friend
Phlargo
865
I'm afraid if I reply to this thread, MS will trace me through my wireless internet and drag me out of Worker's Compensation class for defiling their xbox.
