LTC8K6
lol okay? and?
was that on the op list?
The mid-grade is purely there to make more money for the station
Try to keep up... 😀
:beer:
lol okay? and?
Originally posted by: LTC8K6
semi-hemi
Yeah, it shuts off 4 of it's cylinders a lot. 😀
Originally posted by: LOUISSSSS
Originally posted by: Fenixgoon
the reason for using specific octane ratings is to prevent premature detonation (engine knocking). engines with higher compression ratios (or forced induction) generally need higher octane gasoline so as to prevent the fuel/air mixture from igniting due to compression alone (the mixture heats up as it is compressed). diesel engines, on the other hand, have *very* high compression ratios and use this to ignite the diesel/air mixture instead of having a spark plug.
i use the highest octane available whenever i fill my car (99 VW Passat 1.8T). the recommended minimum is 91 octane in my case.
if your mfg recommends 91, why are you using 93 then? according to your reasoning above, anything above what is recommended is 100% wasted + will lower fuel efficiency (mpg)
No one cares if it's really a hemi, any more than they care what vortec or triton or duratec or duramax or vortec max or iforce or endurance or northstar means, or any other engine marketing terms...
They are all marketing, so why single out Chrysler's marketing? The engine is part of the hemi lineage.
Besides, my hemi is in a Jeep, not some cheap Chrysler. 😀
how do you guys explain to a 50 year old man who's been driving a large SUV that is recommended 87 octane that putting in 93 octane gives u 0 performance benefits (hp/torque) and 0 fuel efficiency benefits?
Your Jeep is a cheap Chrysler.
Haha, good luck with that one. You could probably show him all the tests done on several cars including the exact one he drives, and he would probably still reply with something like, "I don't care what they say, it feels better to me."
he says he feels the torque with the 93 octane...
he also says he puts in "Octane Booster 110+" when he was doing car service, and he said he always got to the customer first...
