pantsaregood
- Feb 13, 2011
- 993
- 37
- 91
The ice cubes won't break 0 C without melting, yes. I don't really see how that's a trick question.
<snip>
AMD basically assigns this TDP based on the highest member of the family tree and the lesser models typically run somewhat lower. Just because they state a chip runs 80W or 95W doesn't mean it runs that constantly. The TDP is more of a guide to the OEM system builders out there (think Dell, HP, etc) to know the maximum heat they will have to dissipate from a given CPU at stock settings under load.
The CPU being a "Black Edition" has absolutely no bearing on the CPU's heat production.
There is more to a CPU than its core count. A large portion of the Phenom II die is covered by L3 cache, a memory controller, and HT links. On any model, be it X2 or X6, these are the same.
Scenario:
I had a Phenom II X2 550 BE (Callisto, or Deneb with two defective cores) clocked at 3.7 Ghz being fed 1.45 volts. Says 80 Watt TDP.
Small FFT test - Maxed out 53 Degree Celsius on stock hs/f
According to this thread:
http://www.xtremesystems.org/forums/showthread.php?182095-Naked-Phenom/page2
The heatspreader is soldered on.
And removing it doesn't result in lower temps.
I'd say the heatspreader does its job.
