- Jul 28, 2004
- 2,618
- 5
- 81
Scenario:
I had a Phenom II X2 550 BE (Callisto, or Deneb with two defective cores) clocked at 3.7 Ghz being fed 1.45 volts. Says 80 Watt TDP.
Small FFT test - Maxed out 53 Degree Celsius on stock hs/f
Upgraded to a Phenom II X4 B93 (basically an 830 like I have in my sig) clocked at 3.2 Ghz at 1.4 volts. Says 95 Watt TDP.
Small FFT test - Maxed out 44 degrees - same hs/f
I'm a little confused. The Quad had a higher TDP at stock speed (I have it at a mild 400 mhz OC right now) and it has 2 additional cores, why did the temperatures drop?
