Born2bwire
- Oct 28, 2005
- 9,840
- 6
- 71
Originally posted by: dmcowen674
There is a system that tranlates GPS underwater but it is top secret technology.
Not sure how he got in here, but I'm hoping it was a one-time thing.Originally posted by: Born2bwire
Originally posted by: RESmonkey
Isn't there a way to get GPS itself underwater? Like, refracted waves could be translated back and forth? Or is GPS not even EM, but the other wave form (longitudinal?)?
if it means anything the gps on my phone poops out in the Chesapeake Bay tunnel
Once upon a time, they wanted to build a submarine antenna in the UP of Michigan. It was for 18KHz. It was soethin glike 50 miles in length.
It was at least delayed for a while beause they were afraid it'd make the cows sterile, but I believe it was ultimately built (~15-20 years ago).
ULF / LF can penatrate the Earth and the oceans. However, the data rate is so small, they are restricted to small letter groups that are coded for specific actions (like 'AA' = "Surface RFN and get a real important message via UHF / SAT")
FWIW
Scott
How do submarines navigate?
I always thought they used GPS, though I could definitely be wrong.
Sorry to get slightly off topic OP
If you read How GPS Receivers Work, you realize that GPS signals are fairly weak. They are coming from satellites orbiting at 11,000 miles. By the time the signals get to earth, they are so weak that even heavy tree foliage can block them.
Therefore, the only way for a submarine to use GPS signals is to come to the surface or to tow a buoy that is floating on the surface. There is no way for GPS signals to penetrate the water.
So how do submarines navigate when they are underwater? The most important tool is the inertial navigation system. An INS uses precise accelerometers and gyroscopes to keep track of every change in the submarine’s speed and direction. A computer monitors all the changes and therefore knows where the submarine is. Obviously over time small errors add up, so the submarine will come to the surface periodically to get a GPS reading and recalibrate the system from a known point.
Directional oil drilling uses "mud thumping" with the drilling mud that is pumped down the drill hole to communicate with the drill bit to determine bit location and direction of travel and to send steering info.AS an alternative you could use sound waves - obviously not from a satellite - which could create a triangulation system. We read that whale song can run hundreds of miles - presumable an artifical analogue could be created. Not sure why one would want to though - and it might further confuse the whales and dolphins who already have to put up with terrible sound pollution.
