I have this micro slicer that I was asked to take apart and look at since it was acting up. Basically it is a razor blaze that vibrates laterally and moves forward and backwards. I took the case off and tried to see if anything was overtly wrong and I touched an alignment bracket connected to a linear screw type actuator and got a little shock (felt like 220V 50Hz, because this company seems to use line frequency and power to operate the solenoid that makes the lateral vibrations.) Couldn't find anything mechanically wrong so I put it back together and no dice on the linear motion. Not sure if something got burned out when I was shocked or if it taking it apart jiggled something else, just trying to see how likely it is the motor or solenoid crapped out from that shock.
