Originally posted by: dullard
Originally posted by: Amused
There is no such thing as destiny, either.
Here: are you happy? It doesn't make your "no luck" argument correct, but I'll change one word that is meaningless to my argument and repost it.
By stating that it is all ability and advantages, you imply that we have complete control over our life's course. I'm disagreeing with your implications - not your words.
Coincidenses, for all intents and purposes, can and should be defined as luck. They are both factors beyond your control. In your life, you have things you can control and things that you cannot. You will likely do quite well if you do the things you can control very well. You may do quite well if the things out of your control just happen to benefit you. That out-of-your-control good fortune can and should be called luck.
