Can a hardware upgradeaholic like myself get by with Vista OEM?
Tom
Originally posted by: Smilin
ROFL. Less bitter. m'kay good luck with that. What you're really asking is if someone has experience violating their EULA and running OEM Vista on more than one rig.
You might get "less bitter" but more than likely you'll just get your thread locked.
Good Luck!
No, same PC. It may turn into a whole new PC in a couple years, but same PC.
k. If you don't upgrade your mobo then you'll be good to go for years to come with OEM.
If you upgrade your mobo then according to your EULA you have a new PC and everything I've already said applies.
Anyhooo. Good luck again! :)
you are hitting the kool-aid hard tonight ! ;)
what country do you live in where replacing a motherboard is a "criminal" act ?
btw, Microsoft doesn't get to decide what violates their EULA, and how it's affected by copyright law and reasonable use, in the United States anyway. Not yet.
