There are a couple problems with this statement. I think all of them can really be summed up with one word: servers. Servers are not shut off. Servers run 24/7 for months and often years at a time. Granted, hard drives especially will likely be swapped and/or may be higher quality SCSI drives, but they still operate non-stop (depending on the servers role). Yes, use the power saving features of the computer. That's still leaving it on. As for wear, by the time the constant wear damages your hardware to the point of malfunction, you more likely than not will have long since replaced it. And incidentally, powering the components off and on repeatedly causes far more wear than just leaving them on. Similar to a light bulb. Notice how more often than not a bulb blows when you turn it on? Rarely do bulbs go bad when they are left on. Same basic deal with your hardware.There are a couple of problems with leaving a PC on:
Power consumption: PCs consume quite a lot of power - a mid-range system could use as much as 150W excluding monitor. Leaving that base unit running 24/7 would cost me about £10/month (representing a near 40% increase in my electricity bill).
Wear: PCs contain mechanical parts such as hard-drives and fans. 'Consumer grade' hard drives such as would be found in a typical home PC are only designed for intermittant use (300 power-on hours/month is typical). Usage of such drives in a 24/7 system could shorten their life, which for consumer grade drives is often already short (3 years expected life-time - 1 year warranty). Other parts such as fans also have limited lives - this shouldn't be a problem for a Dell, but for cheaper PCs, with low-cost components, fans are prone to clogging with dust, or simply failing. Even the electronics wear out - certain components (particularly capacitors) are often running under high temperatures and electrical stresses and have a finite lifetime (10k - 20k hours)
In my opinion PCs should be switched off when not in use, or at least put into standby mode, so that the bulk of the components are powered down when not in use. You'll save energy, money and your PC will probably last longer.
\Dan
This was meant to be a more general comparison, not a side-by-side one. The bottom line is that turning on and off your components will damage them more than leaving them on (or off) constantly will. Also, the CPU is not the only component inside a PC.As for wear, by the time the constant wear damages your hardware to the point of malfunction, you more likely than not will have long since replaced it. And incidentally, powering the components off and on repeatedly causes far more wear than just leaving them on. Similar to a light bulb. Notice how more often than not a bulb blows when you turn it on? Rarely do bulbs go bad when they are left on. Same basic deal with your hardware.
\Dan
I'm not so sure about that. Maybe it's true, but based on my understanding of what causes failure in processors, I don't think you'd have similar surges in processors like you do in lightbulbs. Bulb filaments go through HUGE temperature changes very quickly, CPUs heat up slower (if you use a heatsink).
Originally posted by: drag
What a bunch of BS.
First off unless your running some distributed computing clients or a stupid screensaver (repeat after me: Screensavers are worthless and suck) you computer will use around the same power then a 60 watt bulb. Depending on your setup you can get much less then that if you use power-saving componates and are smart about your hardware choices.
(I've seen the articles that say: "a computer on average uses 125watts per hour so the 13 hundred billion thousand computers in the US use a average of 13,000 thousand billion volts and will kill us all with their AMD proccessors heating up the air... blah blah blah.)
It depends - my AMD 2500 system with Radeon 9700 and 2 drives with conventional cooling uses 180W at idle. Yet my celeron 766 system with integrated graphics uses less than 40W.Now if your running something like 8 drives with a overclocked CPU with peltiers and a water cooling setup, then you probably will be using around 150 watts at idle.
Agreed.The monitor is the biggest thing, these wear out. You want power-save or put it to sleep or something like that, or just shut it off when not in use. They are NOT solid-state, and they use over 200watts easy to keep them running. Mine shut off about 5-10minutes of non-use of the keyboard/mouse.
If your cpu heats up, or needs to "cool off" then their is something wrong with your computer. This is not normal.
I don't get that impression from the manufactureres. E.g. Hitachi deskstar drives are designed to be used for 8-10 hours/day, and can be started/stopped about 50,000 times (about 50 times/day for 3 years).Harddrives get worn out FASTER by shutting them off and on.
Now SCSI's are noted for long life for continous use, but this is file sharing and proccessing stuff 24/7. A IDE drive doesn't get used or worn out just because it's on.
Possibly, though that shouldn't be an issue with modern PSUs - the high voltage components stay powered all the time, so there should be minimal stress.PSU's get worn out FASTER by turning them off and on.
Computers, like most every other solid-state electronic device out their (like your stereo reciever) is perfectly happy left on.(lightbulb is NOT a good example. Lightbulb works continously when left on. Computers and stereos will use very little energy when not being used, if they are properly designed) The wear and tear only happen when you use/abuse them. Some cheap VCRS will use even MORE energy when turned off then when their running.
Hell I have a computer I use as a router that's probably close to 6 years old, and It's left on 24/7 for as long as I remember.
Now as long as everything is working and your computer isn't accessing swap continously their will be little-to-no issue.
It realy depends on your user habits. If you use the computer for 2 hours then you don't use it again till the next day... then shut it off.
If you randomly use the computer all day long and would normally have to turn it off and on, off and on thru the entire day, then keep it on.
If you have a family that is always on and off the computer, then leaving it on can actually save energy in some cases. Booting up and initializing everything all the time can suck some watts.
look here if you don't beleive me
Now with good design and good selection of parts these computers use 78 watts under normal use. A average computer I figure will run about 125-180watts under normal use, even 3.0ghz ones. And then between 40-100 at idle. If you can get power saving and acpi stuff working properly you can reduce that even buy quite a bit.
The computer I am using right now to type this post is at my workplace. This desk is manned 24 hours a day. The computer is never off. It isn't always in use, but needs to be ready for use at all times. The computer is at least 3 years old (that's how long I've been here, and the PC was here before I was). There are no problems with the PC. It runs flawlessly. I'll bet it will continue to run flawlessly. It's loaded with consumer-level parts. My file server rig has 2 consumer-level Western Digital 13GB hard drives in it. They are at least 5 years old. Other than install or upgrade times, they have been in a machine that is on 24/7. Know why I haven't replaced the old slow drives? They still work. They are my oldest hardware of note. Everything else has been replaced, and most of it probably still works (much of my hardware was either passed on or is sitting in a box).The problem is that computers are not fully solid-state, and that some parts run at high stresses where they do have a finite lifetime - just like lightbulbs. This should be of little consequence for most people - but I frequently see offices leaving their PCs on all night (when they start at 9am and close at 5pm) - you have to wonder whether they are shortening the lives of the PCs.
Now if your harddrive light is flashing away even 5 minutes after you stop using the computer, your computer has some serious problems. If you have a computer that is continously accessing the swap file, then don't leave it on.
Can a computer running WinXP (Home) be left on 24/7?
Sounds like your computer is pretty screwed up. Hardly "fine". In fact, I'd consider that completely unacceptable for my computer.Originally posted by: Oyeve
I leave my PC on all the time and am running winxp pro on it. I have six HDs and all sorts of stuff and on the rare occasion I will wake up and notice that the PC has either locked up or has rebooted sometime during the night. Most of the time that this happens winxp reports something about the video drivers. I run an ATI 9500 pro and it can get extremely hot. This usually happens about once a week. Nothing major, just reboot and all is fine.
Originally posted by: RaNDoMMAI
HI
sorry for the noob question
but is it bad to restart your computer kind of alot?
After i play horizons or a FPS game i like to restart my computer because everything seems to lag. It takes a while to start programs and stuff.
I restart my computer and everything rans fast again.
IS this bad?
~RaNDoM
Originally posted by: MercenaryForHire
Sounds like you've just got some bad software configuration or a memory leak going on there. What OS are you using, and do you update it frequently?
- M4H
