Can a C++ constructor call another constructor?
manly
13,549
4,227
Originally posted by: Ameesh
yes you can have one constructor call another.
just add it to the end of your declaration of the specialized constructor
MyClass::MyClass(int a, int b) : MyClass()
//do stuff
Thanks! I like that approach better than having the same code in 2 different places.
Oops, that didn't work. Gave me the following error:
C:\Program Files\Microsoft Visual Studio\MyProjects\myCode.cpp(37) : error C2614: 'MyClass' : illegal member initialization: 'MyClass' is not a base or member
I think that only works if you want to call the superclasses' default constructor.
Exactly. See my post for the correct answer. ;)
Ameesh
23,686
ok this builds fine:
StormRiderTest.h:
class StormRiderTest
public:
StormRiderTest(void);
StormRiderTest(int apple);
StormRiderTest(int apple, void * monkey);
~StormRiderTest(void);
private:
int privateA;
void * privateB;
StormRiderTest.cpp:
StormRiderTest::StormRiderTest(void)
StormRiderTest(0,NULL);
StormRiderTest::StormRiderTest(int apple)
StormRiderTest(apple,NULL);
StormRiderTest::StormRiderTest(int apple, void * monkey)
this->privateA = apple;
this->privateB = monkey;
StormRiderTest::~StormRiderTest(void)
and that does exactly what you want it to do (i tested it and it works)
vtqanh
3,100
StormRiderTest.h:
public:
private:
int privateA;
void * privateB;
StormRiderTest.cpp:
Nope
Your code compiled and ran fine. But it did not do what StormRider wanted it to do.
Do some testing and you will see what i mean.
The call StormRiderTest(0, NULL) in the first constructor basically creates a temporary object. It will be destroyed right after the call is finished. It has no effect on the object that is calling it. (put a cout << "destroying object"; in the destructor and you will see better how this works)
manly
13,549
4,227
We don't think that works, but even if it does, the constructors should be consolidated to just:
StormRiderTest::StormRiderTest(int apple = 0, void * monkey = NULL):
privateA(apple),
privateB(NULL)
vtqanh
3,100
privateA(apple),
privateB(NULL)
well, ameesh was trying to answer the question "Can a C++ constructor call another constructor."
manly
13,549
4,227
privateA(apple),
privateB(NULL)
And obviously, my point is that default arguments are the way to achieve the same effect.
Ameesh
23,686
privateA(apple),
privateB(NULL)
yep, i made the goof, now i know why our coding standards calls for a virtual init function to be called after construction of a class. :eek:
the default argument method is probably the best way to handle this
