SlowSpyder
- Jan 12, 2005
- 17,305
- 1,002
- 126
My gun uses a 7.62 x 54. My buddies gun uses a 7.62 x 51. And also very common is a 7.62 x 39. And there are probably more 7.62's then that, I'm no expert.
Originally posted by: sdifox
Originally posted by: Nebor
Originally posted by: Summitdrinker
5.56 do not tumble thumbo as much as people think
maybe we should watch this fanbottle dude
he never drink beer, beer and guns do not mix for newbies of either
Tumbling is a common term that most people understand. In reality, the 5.56 tends to "yaw" inside human flesh (or ballistics gel) creating a larger wound channel than if it stayed dead on course.
And there isn't much you could hide behind that would provide you adequate cover from a 7.62x51mm (.308 Win.) While certain a concrete wall 6 inches thick will stop it, that's around the bare minimum. A full metal jacket round will easily penetrate 1" of regular (non-hardened) steel. There is no place behind a car that would shelter you from a .308. Standard brick, or cinder block walls have 0 chance of stopping a FMJ .308.
OF course there is a place behind a car that would shelter you from a .308, it's called hide behind the engine.
Originally posted by: Lalakai
as someone noted above, depends on projectile type/construction. armour piercing round should be able to penetrate masonary brick wall fairly easily. Standard ball ammo might have trouble as it would "mushroom" and spread the force of the impact. Armour piercing is constructed to shed its skin as it penetrates, keeping it's core intact and the kinetic energy moving forward in a tightly focused point.
sounds like a good myth buster episode though
And we're all poking fun at the OPOriginally posted by: RagingBITCH
Originally posted by: jjones
Might be bolt action.Originally posted by: RagingBITCH
Originally posted by: JoePa
My bet is on the cartridge staying in the gun.
The cartridge would eject after it's been fired.
I was poking fun at him![]()
Originally posted by: Kelvrick
Which 7.62. Thats the bullet, but there are so many versions of the casing lenghts behind it.
EIther way, I think they'll all pass through it no problem unless they hit a solid wood stud or something.
i have put a 7.62X39 thru a 4" or 6" concrete wall of an old bunker before (it was old, may have been weakened by age and weather tho). that was the old chinese fmj steel core rounds tho, the russian hollow tips wont go thru it. this was at 20 or so yards. it was pretty cool, it left the jacket on the outside of the wall and the steel core stuck in the opposite wall inside. i wish i had kept a half crate of those chinese rounds, im too lazy to look up places to get those again.
other notable things they will go thru... turntable, washer weights, car doors, Kmart gun safes, 18" stuffed barney dolls, kegs, jeep seats, tires, 21" TVs and people. the people one im assuming, the others have been tested.
As noted, shens. They don't bury the survivors either.Originally posted by: fanbottle
can it?
can rifle cartridges penetrate through walls or is this all shens?
Originally posted by: halik
are you throwing the cartridge at the wall?
