Just bought a second hand 21" EIZO F77 (the model that looks as if someone has showed it into a wall). I have two problems with it, one major and one minor that I can live with:
1) The image is slightly blurred at all resolutions and refresh rates! Especially so at the edges. I have tried to adjust the various settings in the monitors menue, but the best I can come up with is the Auto setting. I downloaded a proggie from EIZO (Screen Manager I think it was called) but to use it I need to plug in a cable in the monitors Maintainance Port and the com port. If i get this cable, would this program enable adjustments that could cure the blurrieness?
2) There is visible banding on the screen (don't know the technical word for it). This appears at all resolutions but more at some. Changing refresh rate does very little here. I know there is a setting in the monitor's menue that allows me to adjust this, but fiddling with it only makes the screen more blurry and doest very little about the banding. Is there anything I can do about this?
I'm using a V3, latest drivers, the right monitor is installed (not plug and play). Have also seen the monitor a S3 PCI card, which gave the same result.
