Calling math wizs, I need some double checking...
SithSolo1
Ok my friends and I have spent the past 15mins calculating the number of lottery combinations for 3 lotterys and this is what we came up with:
Lotto 3: Pick 3 numbers 1-9 in any combination. 9^3=729
Lotto 6: Pick 6 numbers 0-9 in any combination. 10^6=1,000,000
PowerBall: Pick 5 numbers 0-9 in any combination and then 1 more ball 1-45. 10^5= 100,000 x 45 = 4,500,000
These all seem too low, what am I missing?
It depends if you put the ball back in to the pool.
If you don't put the ball back in, it would be 1/9 * 1/8 * 1/7
Lotto pick 6 numbers would be: 50 x 49 x 48 x 47 x 46 x 45 = 11,441,304,000
assuming that there are 50 numbers to chose from (1-50) and you don't put the ball back in after it has been drawn.
Durr I knew I was forgetting something! Lotto is like 1-45 for each number
As you can tell I have never played
Here's an example:
If you have 49 balls and 6 get picked then it's:
1/49 x 1/48 x 1/47 x 1/46 x 1/45 x 1/44 etc.
multiply all those and you won't feel so lucky.
i think i'm wrong somewhere. my number seems to high.
Originally posted by: jagr10
Here's an example:
The formula for the number of ways to pick n balls from r possibilities, assuming the order matters and balls are not replaced is:
n!/r!(n-r)!
Picking six from 49 gives you about 14 million different possibilites.
