Calling all E6300 and E6400 owners
Skott
5,730
1) E6400
2)2.664 @ 43/44C idle - 55C Full Load
3)Since August/September
4) None but its a mild 25% OC
5)Zalman 9500 AT (31C/32C @ stock speed)
ScottFern
3,629
1. E6400 - 2.13Ghz
2. 3.5Ghz (500fsb x 7) 42C/59C idle/load
3. 2 weeks ago
4. Once it wouldn't boot up, but I reset the PSU and never happened again.
5. I have lapped the E6400 IHS and I am using a Tuniq Tower + AS5
Dolorous Dave
317
1. Processor and Stock Speed
2. Current Speed and Temp.
3. Time that it has run overclocked
4. Any issues?
5. If you are using a custom HSF, then please post your overclocked speed with the stock cooler as well.
1. E6400 2.13GHz
2. 3.2GHz, 46-48C under Orthos loaded, stock voltage across the board
3. 2 days (14 hours Orthos Stable, still running)
4. Nope.
5. Arctic Freezer 7 Pro, could get 3.2Ghz on stock but temps were over 60C at load.
nerdye
16
Hey Core 2 Duo Owners
1. e6200 running on a 965 ds3
2. stock 1.86 ghz running at 24c idle, around 40-ish on load (pc wizard)
3. 2.5 months ownership
4. I've had no issues
5. I use a mini typhoon cpu cooler with artic 5 thermal paste,
I also run this in a roomy antec 900 series case (with the small pizza
size fan on the top of the case)
I plan on overclocking when its necessary but my rig equipped with a 7950gt
has given me good enough performance that I can wait...
-E
Alone
7,490
1. E6300 @ 1.86GHz
2. 3.43GHz @ 30-40*C Idle
3. One week
4. None on idle, high temps on load (sometimes)
5. Watercooled.
TheJQ
20
1. E6400 @ 2.14
2. 3.5 Ghz/1.3625v @ 40 idle - 52 full load
3. 2 weeks
4. None
5. Big BT
amenx
4,547
2,886
E6400 @2.13
3ghz @1.325v /36 idle - 44 load
3 months
Stock HSF
issues: runs very well as is, but cannot go higher than 3ghz or 390fsb (401 dont work either) no matter what VCore, FSB, MCH or RAM voltages/timings I try. :(
RussianSensation
19,458
765
1. E6400 2130mhz
2. 3400mhz at 1.375v, Idle 39*C Load 51-52*C (Intel Thermal Analysis Tool)
3. Overclocked since October, 2006
4. Big Typhoon, have not tried overclocking with stock cooler.
Have not tried overclocking any farther. No issues.
