Cable modem problems
snidy100
31
I got a cable modem, first I had the usb, I kept getting disconected, so I had to restart my computer, then it would work for a couple of minutes, then disconect again, so I went for a PCI ethernet card, and it won't conect at all, everythings configured corectly, I've called tech support about 20 times, I reformated and re installed windows, and still nothing, any ideas?
JackOfHearts
667
I had that same problem... It turned out that the spilter they used was bad... In the end the ran a sperate line for my cable modem... and I got 2 free months of service... just like call tech support and b1tch a lot....
benjamit
775
i have road runner with time warner
the s/w uses quicktime to setup the IE specific for road runner, etc
and the s/w works fine for 95/98 people (install it without needing internet connection) but doesn't install for nt/2k people
i d/l quicktime from apple to install in 2k before installing road runner s/w but the quicktime installer needs to connect with apple for registration
what problems for something that's suppose to be easy
JackMDS
29,547
423
1. Could be that the installations of Win98, rearranged your IRQ assignment creating some conflict.
2. What about authentication?
Most Cable providers need the MAC number of your NIC to authenticate (Password).
